Haltech LS1/LS2 Coil Wiring
Old Jul 17, 2010 | 10:07 PM
BDC's Avatar
BDC
BDC Motorsports
LS1/LS2 Coil Wiring
Howdy folks, perhaps I've just missed it in my searches but I'm in need of the wiring schematic for the LS2 coil. I found one on a Megasquirt site but the diagram doesn't line up right with the pin labels on the connector clips (A, B, C, D). Does anybody here have an accurate diagram I can go on?
Thanks.
B
Old Jul 18, 2010 | 01:11 AM
Sesshoumaru's Avatar
Tenseiga
Thanks.
B
Attached Thumbnails LS1/LS2 Coil Wiring-coils.jpg
Old Jul 18, 2010 | 09:46 AM
BDC's Avatar
BDC
BDC Motorsports
Thanks, Sess. I owe a favour now.
B
Old Jul 18, 2010 | 11:28 AM
C. Ludwig's Avatar
www.lms-efi.com
The A, B, C, D is the same for both coils. The connector simply has them flipped 180*.
Old Jul 18, 2010 | 12:36 PM
BDC's Avatar
BDC
BDC Motorsports
Ok, Chris. So go by the A, B, C, etc labelling then?
Old Jul 18, 2010 | 12:57 PM
C. Ludwig's Avatar
www.lms-efi.com
Yes. The lock on the plug is just flipped over so it looks different. Put the pinout as it corresponds to the letters is the same.
Old Jul 18, 2010 | 01:05 PM
BDC's Avatar
BDC
BDC Motorsports
Aha! That's it. That cured my confusion on it. Thanks!
Old Aug 30, 2012 | 10:36 AM
mzrx7man's Avatar
sideways!!
i know its around but it would be nice to have all the info in this thread. what are the settings i need to change on an e6k to run ls2 coils?
Old Aug 30, 2012 | 11:09 AM
C. Ludwig's Avatar
www.lms-efi.com
You're limited to around 3ms with the E6K/X. Since they fire the leading in wastespark, the duty cycle catches up to you at high revs. You can program the ECU for more, but it will cut short the charge time at higher revs when duty cycle dictates.
Old Aug 30, 2012 | 11:25 AM
mzrx7man's Avatar
sideways!!
what rpm am i limited to at 3ms? would this setup still benefit me over stock coils?
windom
Adaptronic Engine Mgmt - AUS
Sep 11, 2015 04:48 AM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
