Intercooler Comparisons
Old Jul 23, 2002 | 08:05 AM
CHRIS P's Avatar
These are a few intercooler temp drop comparisons that I have been taking.
I am currently developing a front mount kit which should be less than half the prie of the current front mount IC's
More Info To Follow!
Old Jul 23, 2002 | 08:09 AM
CHRIS P's Avatar
Why cant I attach these xls?
Having a little trouble attaching these files, any ideas
Old Jul 23, 2002 | 08:14 AM
CHRIS P's Avatar
more tests
Sorry about one table per reply, but cant submit a folder
Old Jul 23, 2002 | 08:15 AM
CHRIS P's Avatar
skyline xls
Nissan Skyline 1995 gtr
Old Jul 23, 2002 | 08:16 AM
CHRIS P's Avatar
mr2 1992
two more to go
Old Jul 23, 2002 | 08:54 AM
skunks's Avatar
I'm a CF and poop smith
wow nice research, did you happen to get the dimentions of these different intercoolers?
Old Jul 23, 2002 | 09:38 AM
Freaky Monkey007's Avatar
Yes very very nice research... How exactly did you conduct this?
Old Jul 23, 2002 | 10:26 AM
jr's Avatar
jr
Very nice to see some real data numbers. I love the stock Skyline data! I can only hope the Apexi C2 Skyline core used in the RX7 Fashion/Turbo Streetfighter IC's is similar. Could you please tell me what equipment you used to conduct these tests? I'd like to do similar testing myself.
Old Jul 23, 2002 | 12:06 PM
CHRIS P's Avatar
The kit is a 8 channel data logger with temp ranges on the probes used from -20 to +1150 at 0.025deg resolution.
The kit plugs straight into your laptop and gives an instant graph and table with up to 500 recordings. Sampling can be varied from every 0.1 of a second up to several minutes between recording data
So far I have carried out several tests on the following vehicles:
FD3S 1996 stock IC (Power FC running 0.8Bar)
FD3S 1996 Uprated IC stock location(Power FC running 0.8Bar)
FD3S 1992/3 front mount apexi
FD3S 1992/3 Front Mount Blitz
Toyota Mr2 1992 Stock IC
Nissan Skyline 1995 Stock IC Running 1Bar
As You can see the skyline as standard is over engineered, the front mount apexi and blitz were both excellent units, however price was high. aswell as the int in/out temps, I was also monitering air on/off int ambient and air filter inlet temps.
The skyline had an apexi induction kit, which gave v-high temp readings of air being drawn in after standstill up to approx 70mph, before there was sufficient cool air forced through the engine bay.
Hope these are of some info.
Chris
Old Jul 23, 2002 | 12:10 PM
RX7Elmo's Avatar
very usefull data indeed,
I'm curious why on the stock RX7 IC as well as the MR2 IC the intake temps were so erratic going up and down? Is this from shifting through the gears etc?
danny
Old Jul 24, 2002 | 02:13 PM
jr's Avatar
jr
Thanks for the info on the unit. Sounds like a very nice setup. Do you know where I could get something similar here in the states? Brand name and/or model number? Thanks.
Old Jul 24, 2002 | 04:46 PM
JspecFD's Avatar
I haven't been able to download the file properly. its downloading as attachment.php instead of an .xls file and Excel can't read it Any helpful tips? thanks
Old Jul 24, 2002 | 05:05 PM
GoRacer's Avatar
Speed Mach Go Go Go
Attachments on this site allways do that
Just rename the extesnion (.php) to ".xls" and then you will be able to open it.
Old Jul 24, 2002 | 07:37 PM
rpm_pwr's Avatar
GREAT WORK!
where's the FD uprated SMIC chart though?
Old Jul 24, 2002 | 09:40 PM
JM1FD's Avatar
danny
The cores aren't large enough to shed enough heat to flatten out the spikes, thus the spikes go right on through to the outlet, plus the small cores are heat soaked after the first few minutes.
Old Jul 24, 2002 | 09:42 PM
JM1FD's Avatar
Very nice! I'd like to see some data for ambient air volume & temperature through the core, or at least vehicle speed conditions. Also, where are the numbers for the larger stock mount RX-7 intercooler? How much did that logging setup cost?
Old Jul 27, 2002 | 07:40 PM
rpm_pwr's Avatar
*BUMP*
Is anyone else waiting for the upgraded SMIC chart? This would help settle the SMIC vs FMIC debate.
-pete
Old Jul 27, 2002 | 07:49 PM
CCarlisi's Avatar
Rebreaking things
agreed. I'd also like to see pressure drop info on the Blitz. Anyone know where I can find that? (got lost searching).
great job Chris.
ls1swap
Jun 3, 2024 03:25 PM
1NSIGHT
Sep 25, 2015 12:59 PM
AXA
Sep 5, 2015 10:06 AM
