Just got the car off the dyno...
Old Jun 6, 2002 | 09:01 AM
AJC13B's Avatar
10.32 @ 133
Talking Just got the car off the dyno...
Final result was 354rwkw (471rwhp) and was on a Dynamic Test Systems dyno, which ready around 15% less than a Dynojet.
Fuel was C16. Boost was 26psi. Plugs were BUR9EQ. A/F was 11.7. Tune was by HITman.
http://www.ajc13b.com/dyno_1.mpg
http://www.ajc13b.com/dyno_2.mpg
http://www.ajc13b.com/dyno_3.mpg
Dyno graphs to come....
I am pumped boys
Old Jun 6, 2002 | 09:06 AM
zyounker's Avatar
root
Congrates!
Those plugs seem a little hot to me. what kind of split timming are you running?
Thanks,
-Zach
Old Jun 6, 2002 | 09:14 AM
AJC13B's Avatar
10.32 @ 133
10 degrees split. Tried 0 split and lost 10kw.
I am hunting down a 10 heat range in the surface dishcharge type plug....
Old Jun 6, 2002 | 09:19 AM
RXTASY1's Avatar
I am pumped boys
You should be! Nice numbers!
Old Jun 6, 2002 | 09:26 AM
zyounker's Avatar
root
Cool.. Just wanted to know because we cracked my friends rear plate running 9s and thought it was either the plugs or the 0 split timming..
-Zach
Old Jun 6, 2002 | 09:34 AM
AJC13B's Avatar
10.32 @ 133
HITman played with a 13B PP earlier today and tinkered with lead/trailing split and the engine didn't like it at all, it missed actually I think he said. And we lost 10kw doing it on mine....odd
Old Jun 6, 2002 | 10:52 AM
Boostn7's Avatar
Nice numbers !
Did you tried any higher then 10 degrees split ??
I've run the 9EQ's to a bit over 500rwh...and no misfires with A/F in the 11.8-12.2...
Later
Old Jun 6, 2002 | 12:29 PM
VELCRO SHOES's Avatar
I thought you were expecting around 600 hp?26 psi just seems like alot of boost for so little Hp???Still alot though
Old Jun 6, 2002 | 05:09 PM
AJC13B's Avatar
10.32 @ 133
Velcro - DTS dynos read around 15% less than a dynojet. So 471hp on this dyno is around the 560mark on a dynojet.
Old Jun 6, 2002 | 07:21 PM
Max7's Avatar
Admitted Sevenaholic
Looks like someone is going to be having to look for fender flares to get some more meat under the rear
congrats on the new HP #'s! come on 10's!!!!
Old Jun 6, 2002 | 09:46 PM
What size turbo do you have?
Old Jun 6, 2002 | 11:43 PM
AJC13B's Avatar
10.32 @ 133
TA45
72 a/r cover with 68mm blade
1.05 exhaust housing with 68mm blade
The newer TA series turbos are larger frame turbos than the generic T04 size turbos.
Old Jun 7, 2002 | 12:16 AM
thats a big bish,bigger than my HKS T51R-KAI.
Old Jun 7, 2002 | 03:59 AM
AJC13B's Avatar
10.32 @ 133
Dats right baybee
Old Jun 7, 2002 | 04:50 AM
SPEED_NYC's Avatar
RX-Parts
Steve do you have ant engine bay/turbo pics of the new set-up?h
Old Jun 7, 2002 | 05:08 AM
87GTR's Avatar
wooo hooo!!! Congrates!!!
on the number!!
you should give it a try on come 10.5 or 11's
now when you going to hook me up with that shift kit so I can shift mad quick ?
Old Jun 7, 2002 | 05:37 AM
HWO's Avatar
HWO
inteligent extratarestril
-Zach
the motor detonated, otherwise the plate wouldn't have broken. I hear about more people breaking plates with 300-350HP than i heard about guys making 350+hp
Cracking plates seems to be the result of detonation caused by too higher intake charge often the result of a T04 hybridised with the stock compressor running more boost that the octane rating of the fuel allows. More of a case of pre ignition i think
Old Jun 7, 2002 | 05:39 AM
HWO's Avatar
HWO
thats approx 650HP at the flywheel for those that cant do the calculations
Old Jun 7, 2002 | 06:01 AM
87GTR's Avatar
if you can keep your car on the ground you should be in the low 10's
Old Jun 7, 2002 | 06:39 AM
Greg's Avatar
Not really, your Kai is like my old T76. His turbo is like a T-70.
Steve, Congrats on the power numbers. Thats 9 second power. Strip that friggen car down and run some 9s
AJC13B's Avatar
10.32 @ 133
Speed -
87GTR - Thanks mate! Will double check the price with my guy and give you the details!
Old Jun 7, 2002 | 06:44 AM
AJC13B's Avatar
10.32 @ 133
Greg - The car has a drivers seat and a dash in it Its ready!!
The blades are bigger than the Kai I think, but the cover is smaller....
Old Jun 7, 2002 | 07:30 AM
Anthony Rodrigues's Avatar
AJC13B,
Put some fuel in it first and try some NGK R6725-115 spark plugs at the higher boost you may be impressed. At 26psi you should just be starting to wake that turbocharger up. Congrats!
REgards-Anthony
Old Jun 7, 2002 | 07:39 AM
Greg's Avatar
Steve, Just boost 4 more lbs Couldnt hurt
Old Jun 7, 2002 | 07:41 AM
Greg's Avatar
Just curious steve, What tire are you going ot be running ?
