Is it normal to bog when getting back on the gas?
Old 02-13-02, 01:01 PM
Eggs are like fowl cheese
supergoat's Avatar
ok, sometimes if I let of the gas due to road conditions....or whatever, then get back on it it bogs and I have to let off then back on and it's fine. Any dea why?
It's mostly in 2nd gear. I'm pretty sure it's not my diff, mounts since there is no clunking coming from the back. The engine revs great and pulls strong. So is it normal to bog down like that sometimes? It's usually aroun 1.5-2k rpms it does this. And no I'm not trying to floor it.
Old 02-13-02, 01:23 PM
mad scientist
mazdaspeed7's Avatar
Sounds like the pressure sensor isnt working right.
Old 02-13-02, 04:57 PM
RETed's Avatar
Or TPS misadjusted...
-Ted
Old 02-13-02, 05:11 PM
rawr
Agent_D's Avatar
yea mine does that too supergoat, ive tried adjusting the TPS, that didnt help any, mine will do it from 1000-2800 rpm sometimes, and when shifting gears.
Old 02-13-02, 05:59 PM
you might want to check the AFM this is the same problem ive been fighting on the 89 vert my sister just bought ive replaced the TPS,oil metering pump and did a complete tune up still did not help i pulled the AFM off and it had a rattling sound to it i tested it and it tested bad i hope this is the fix its driving me crazy not knowing what it is and driving her crazy cause shes had it for going on 3 months and hast been able to drive it my 88 AFM is also bad but it runs lean and has like a drag to it that is a good suggestion though about the pressure sensor mazdaspeed ive never thought about testing that i have 91 intakes on mine and had the pressure sensor tested and it tested right at max so i will have to check that out thanks mazdaspeed
Old 02-13-02, 07:31 PM
supergoat's Avatar
thanks for the replies. Luckily it does not to it all the time. It's very sparattic.
Old 02-13-02, 07:47 PM
yep same prob i have very hard to find i rather just have it go out completely least then i could find the prob
Old 02-13-02, 09:16 PM
SOLD THE RX-7!
Scott 89t2's Avatar
what are you doing driving at 1500-2000? I can't even drive under 2k...
Old 02-13-02, 10:19 PM
mad scientist
He doesnt have a turbo. N/a's have something other than just idle at below 2K
Old 02-14-02, 02:52 AM
If your car is on the very rich side at idle, it will bog when you floor it.
Old 02-14-02, 03:04 AM
Super Newbie
Felix Wankel's Avatar
Probably that stupid TB mod. I did that **** to my car, and it was a waste of time. Now I get to freeze my *** off warming it up in the morning. Might as well have a carb with no choke.....
Old 02-14-02, 03:49 AM
rawr
Agent_D's Avatar
Go adam its your b-day
i regularly drive at 1000rpm and i can idle through a parking lot at 500rpm
Super Newbie
Yeah, no power
Old 02-14-02, 03:53 AM
rawr
Agent_D's Avatar
felix your just dis illsuioned lol
Tylerx7fb
39
05-27-19 12:45 PM
Microtech
30
04-23-16 06:37 PM
smikels
08-18-15 01:26 PM
Quick Reply: Is it normal to bog when getting back on the gas?
