power steering removal
Old Jan 12, 2002 | 01:32 PM
fc3s94509's Avatar
Question power steering removal
i want to get rid of my power steering, would any 2nd gen manual steering rack fit a 87 turboII.
Old Jan 13, 2002 | 12:25 AM
fc3s94509's Avatar
Old Jan 13, 2002 | 05:13 AM
SpeedRacer's Avatar
Formula Mazda Driver
I don't know the answer to your question, BUT...You don't have to put in a manual steering rack. I removed my PS in my 90 NA, all I did was connect the two lines going into the PS pump together after removing the pump. It won't be quite as easy to turn then with a manual rack, but I don't having any problems turning the wheel.
Old Jan 13, 2002 | 07:42 AM
RotorDemonGXL's Avatar
I too removed my Power Steering from my 88GXL... the cheap way. I took off my belt and the p/s fuse. I also took off my A/C Belt too. I tried, but I can't figure out how to remove the console. I wanna lift that whole space as I've seen many people do before but I don't know where to start. All that open space... less weight and a nice, snuggly cozy spot for a T-88? hmm... interesting.
Lemme know guys... thanks
Old Jan 13, 2002 | 08:00 AM
Node's Avatar
If you replace it with a manual rack I think it is quite easier on turning than a unpowered powersteering rack.
Old Jan 13, 2002 | 09:02 AM
Xentrix's Avatar
Kill Bear
I just changed to a manual rack like 2 weeks ago.
1. just taking the belt off is bad, the rack still wants the juice but the pump isnt going.
2. you can cap the lines from the rack but I dont remember wich ones or how. Do a search, alot of people have done it.
3. Go with the manual rack, it is easier to turn than removing the PS belt.
4. If you go manual, the send/receive lines from the pump to the rack are a BITCH to get off, and make sure you have the passenger side mounitng bracket from the manual rack, it is a different size from the PS one, the other side is the same on both racks.
hope that helps
zeff
Old Jan 13, 2002 | 09:50 AM
BiG WaNkLeR's Avatar
My concern before removing my belt was because of Xentrix reason #1 that it is bad for the rack as it want's the juice but it's not getting it. IF I drive without the power steering how bad will this kill my rack? I may decide to put it back on maybe in the future if I sell it or sell it to my bro.
Thanks
Old Jan 13, 2002 | 07:10 PM
bump
Old Jan 14, 2002 | 02:13 AM
fc3s94509's Avatar
cool thank for the info
Old Jan 14, 2002 | 02:31 AM
ItsNiceToBurnRice's Avatar
I removed mine a couple months ago, and I mean the whole system. THe lines are a bitch so I cut them off and capped them. No probs at all and its not that hard to steer. But I didnt removed the fuse, hmmmmm, should I? what will it help?
Old Jan 14, 2002 | 02:37 AM
ROTOR DEMON GXL
you think I shoud pull the fuse, what for?
Old Jan 15, 2002 | 08:18 AM
jarrod's Avatar
I removed my power steering and didn't cut anything saved it all
someone might need it one of these days..
the pain for me was removing the condensor...
Old Jan 15, 2002 | 09:02 AM
damn, you guys
Thanks
takin out hte pump dosent kill the rack. the rack still turns the same way, and if you take the pump out right there will still be fluid in there. the only difference is that you are using your power to steer and not the pump. Granted a manual rack is easier to steer, but ****, its not hard at all, its a little pain just at a stand still.
Old Jan 15, 2002 | 09:22 AM
MikeL's Avatar
I have a manual rack in my '87 TII parts car, for sale, $100 + shipping.
Mike
Old Jan 16, 2002 | 12:27 AM
Jerk_Racer's Avatar
Just exercise a little. I've taken my belt off and have had it this way for the last 9 months or so. If it gets easier when the lines are capped off and not trying to fight the offline pump, then it shouldn't be a problem at all. Right now with just the line off, after a few mph it isn't so bad.
jerk_racer@hotmail.com
Old Jan 16, 2002 | 01:32 PM
What do cap your lines with?
Which lines do u cap?
Old Jan 16, 2002 | 01:39 PM
maxpesce's Avatar
Ex fd *****
Don't just cap the lines - connect them together bypassing the pump - this allows the rack to remain full of fluid for lubrication and allows the fluid to circulate w/o causing extra resistance in the rack.
Old Jul 24, 2002 | 06:10 PM
Wankel Traitor
Make sure to plug the cooling line with a bolt or something. Just connect the 2 lines that go to the PS pump with somethin, not too bad.
Jameson
Skeese
65
Mar 28, 2017 03:30 PM
LunchboxCritter
15
Jan 3, 2016 04:11 PM
LMBTG
Sep 2, 2015 07:01 PM
c0rpse
Aug 25, 2015 11:50 PM
