Budget interior refurbishing.
Old 02-09-03, 05:11 PM
PJ-4.2L's Avatar
Since I have been spending a lot of time on my $50 FC, I decided it was time to get rid of the nasty, old, faded maroon interior. I wanted an all black interior and found that re-upholstering my old dash would be cheaper than buying a used one, sicne the cheapest replacement dash I could find was $150. All in all, I have spent around 50 bucks on this project so far. I am about 70% done with the entire interior.
I won't cover dash removal (use the search button, guys!), but I will say that there was ALOT of dust, dirt, crud and debris inside the dash. And I used to wonder why my car smelled so bad...
Once the dash was removed, I found that the foam was rotten under the old vinyl, which was all cracked from the AZ sun. I scraped everything off with a razor blade then cleaned it all off with paint thinner:
Old 02-09-03, 05:12 PM
PJ-4.2L's Avatar
After that I proceeded to scuff the surface of the entire dash "skeleton." This is necessary to promote adequate adhesion. I am using DAP Weldwood for the vinyl. Read the container's instructions prior to attempting this. Below is a pic of the area above the clock cluster.
After some thought, I decided that it would not be wise to try to adhere the vinyl to the dimples illustrated above. Instead, I used bondo to smooth that area out. See below...
Old 02-09-03, 05:13 PM
PJ-4.2L's Avatar
I also bondo'd the dimple on the length of the dash:
I sanded the dimple area to a smooth, curved finish so the vinyl would adhere easily.
I also bondo'd the corners around the gauge cluster to ease the vinyl fitment. Without the bondo, the composite angles and curves of the corners would not be manageable. The picture below shows results after some sanding:
Old 02-09-03, 05:14 PM
PJ-4.2L's Avatar
After sanding, I cleaned the surface once more. Then it was time for the vinyl (am I spelling that right?). I decided to work top-down since the top was the most visible part.
I used a hair dryer and a roller to heat and mold the vinyl. It takes some time to get it right, but Weldwood is forgiving. Just be sure to not scratch the vinyl. Think ahead and do this part in steps.
Below is a pic of a problem area which has multiple compound curves. It is pretty-much impossible to do this with one single piece of vinyl, so you will need to cut and address the area from two angles. Before tackling this problem, I started to vinyl from the bottom up.
The pics below show the resulting seams after some work. The flash makes them look worse than they are, but you need to remember that I placed these seems in such a way that they are hardly visible once the trim panels and switched are installed.
If the seams bother me when the dash is installed, I will purchase a vinyl repair kit and patch them up. In the end, there are solutions to this problem.
The pic below is of the finished dash skeleton. Most of the seams will be hidden by trim panels. The results thus far are better than I expected. I will update this post with pics of the work I am doing with the rest of the interior, so check back soon!
I hope this helps those of you who are not happy with your interiors.
Feel free to ask me any questions!
PJ
Old 02-09-03, 05:29 PM
What Subscription?
banzaitoyota's Avatar
Nice effort!. Justdashes wants 500 to recover a FC dash
Old 02-09-03, 08:22 PM
coincopy's Avatar
damn man that looks nice!
where did you purchase your vinyl from and howmuch did it cost you? I want to do the same except with 2 colors.
Old 02-09-03, 08:52 PM
PJ-4.2L's Avatar
I got the vinyl from a local car stereo shop. Any good shop should carry some. I have seen vinyl for sale in fabric stores, but it wasn't the kind I wanted. I went to the audio store because they know what kind is best for this sort of project. It cost me $5.50/ foot off of a 5 ft wide spool. I bought 5 feet. I may buy more later if I don't like the way my door panels dye.
I'd like to see a two tone scheme... that would be interesting. BYW, the vent panel at the top, the one that goes between the back of the dash and the windshield, is gonna get dyed too. The grain may not match, but I can always upholster that too if it doesn't look good.
PJ
Old 02-09-03, 09:38 PM
WingmaN
Scalliwag's Avatar
Great work! I like a guy who has the ***** to go after a tough job. If you ever get a dash out that is the best time to put down carpet.
For anyone that is thinking about trying this there is another option you might try; carbon fiber.
This place here has the best prices I have found. http://www.uscomposites.com/carbonpage.html Watch the weight and the widths. The lighter fabric (5.7 oz. as opposed to 19.7 oz.) is workable on something like this.
Since this application is for appearance only then the lighter the better. I won't go into details on this since it borderlines a thread hijacking but since I brought up the option I wanted to point out some things to watch out for.
For vinyl, locate an auto upholstery supply in your area for the best price and selection. I get most of mine from J&J Supply in Fort Worth.
Old 02-10-03, 01:22 AM
No doubt that looks 100x's better than the regular burgandy interior, but have you considered trying the folla tech spray. That stuff is unbelievable, as long as you clean the areas being sprayed properly. This would eliminate the "seam" problem, and be an inexpensive way to change the colour of your interior. Just a thought!
Old 02-10-03, 02:09 AM
Yes, that is my car
JonEQuest's Avatar
Jesus C! I thought I was bad about taking on labor intensive projects, but I have to admit, it is looking pretty good and it was probably a little fun too right? I am currently spending many hours of my time duplicating that projection headlight Aemimya kit myself. even at minimum wage for my labor, I will probably only break even with the $1300 Aemimya cost. But that's part of the fun of having an older car, doing it yourself and being proud of the results.
Good job
Old 02-10-03, 05:23 AM
HyperRex's Avatar
Outstanding! Good job!
Old 02-10-03, 12:10 PM
PJ-4.2L's Avatar
I actually am using Duplicolor vinyl dye on the rest of the interior. I couldn't use it on the dash because the old vinyl was literally crispy, like potato chips. There were chunks missing on the top and the foam below was rotten and black. If the dash is in good condition, I ABSOLUTELY suggest you try dye first. I think many people here will be impressed with the results of a dyed interior. I will dye the door panels tonight.
PJ
Old 02-10-03, 12:12 PM
PJ-4.2L's Avatar
Scalliwag, dude, go ahead and post all the info...
Hopefully this will become an archived budget interior thread, so if anyone else has any advice or info to provide, post it!
PJ
Old 02-10-03, 12:14 PM
PJ-4.2L's Avatar
JonEQuest, take pics of your progress so you can make an "article." I'd be interested to see your results since I've considered that project myself.
PJ
Old 02-10-03, 12:20 PM
What Subscription?
Here's a thought. Make a piece to cover the Instrument Cluster bubble[It will be one piece. Then take the main dash piece down to the Upholstry shop and have them fold back and stich the edge around the Instrument Cluster opening!
Old 02-10-03, 12:22 PM
I'll be starting up my interior project very soon, I'll do a step by step write up for it as well. Stay tuned for it next month. I did the interior in my last car, and it came out very good. My total budget for that car was approx $200.
Old 02-10-03, 12:59 PM
What Subscription?
Here are some links:
http://www.upholster.com/auto/truck.html
Old 02-10-03, 01:46 PM
PJ-4.2L's Avatar
I'm not sure if I'm understanding, but I don't see why I would need to do that... Unless you like the look of stiching...
PJ
Old 02-10-03, 01:54 PM
No longer cares
Jimmy325i's Avatar
Did you think of using vinyl repair for the seams? You might be able to completely blend them away with that stuff.
Old 02-10-03, 03:11 PM
PJ-4.2L's Avatar
Jimmy, read the post, brotha!!!
PJ
Old 02-10-03, 03:26 PM
No longer cares
Jimmy325i's Avatar
Sorry, but I would be doing that long before attempting to re-install the dash....
Old 02-10-03, 03:53 PM
PJ-4.2L's Avatar
You're probably right. I'll go check out the kits at the store.
PJ
Old 02-10-03, 06:55 PM
WingmaN
Scalliwag's Avatar
PJ
Better yet, I will pull a dash and take pics through the entire project. I was sitting in my car today and looking at the dash. My dash is in great shape but I could not help thinking about your dash job.
I imagined what it would look like in carbon fiber and decided I had to do it. There are plenty of jacked up looking dashes out there and I can pull one and get it finished before I take mine out.
If you have ever worked fiberglass and had pretty good success you will do fine working carbon.
The resin is funky **** and it is not something I ever really enjoyed doing.
Old 02-10-03, 07:25 PM
13B N/A POWA!
KiyoKix's Avatar
Nicely done!
Old 02-10-03, 09:52 PM
PJ-4.2L's Avatar
Scalliwag, I actually do have some experience with fiberglass... I actually considered a completely custom dash for a while but I figured that I didn't want to spend that much time on it. Had I done that, I would have incorporated speaker and gauge pods--- oh the possibilities!!!
I'm looking forward to the carbon fiber project, so don't wuss out on it! Does anybody know what happened to the whole "I'm gonna build carbon fiber surrounds," ordeal? I need to buy a new surround.
PJ
