Horizontal intercooler
Old Oct 26, 2002 | 08:13 AM
I just came across this interesting horizontal intercooler,do you guys have any experience w/this unit as far as fitment ,efficiency,hood clearence?It is for a very good price($400)and the buy is tempting,but I'm a little affraid that will run into all kind of problems......
Thanks for all your help
http://www.shaneracing.com/Import_Dr...rage_Sale.html
Old Oct 26, 2002 | 08:17 AM
skunks's Avatar
I'm a CF and poop smith
ooo they got a 20B 3-Rotor Used Engine $2900 (only 1 though)
rxrotary2_7's Avatar
this is what turns up when searching for "HMIC" https://www.rx7club.com/forum/search...der=descending
if any questions after. continue them in this thread, but take the time to read what has already been posted.
Old Oct 26, 2002 | 09:17 AM
vudoodoodoo's Avatar
20B 3-Rotor Used Engine $2900 (only 1 )
WTF?!
If only I had the monies...
Old Oct 26, 2002 | 11:32 AM
rerx7's Avatar
I don't think horizontal IC isn't very effiecent as heat raise up, as for a vertical front mount have all the cool air it can take. Plus it looks sooo cool and gives you a cleaner look at the engine bay
Old Oct 26, 2002 | 05:48 PM
rynberg's Avatar
Supposedly, the horizontal intercooler actually works pretty well.
However, they state that you are buying the intercooler only. That means that you will have to have a duct and the piping custom made. Depending on your connections/resources, this could end up costing a LOT of money. Enough to make that $400 not look like such a good deal.
Old Oct 26, 2002 | 08:15 PM
Thanks for your opinions,I think rynbera is right by the time the project is done it could actually cost me same not even more as good vertical IC.
It's hard to find a good one for arround $500,even used....
Old Oct 26, 2002 | 09:17 PM
R Xplicit's Avatar
sr motorsports has not finished that intercooler. well, from what they told me, they never will. there was a problem with demand, and also the fabrication shop that was making it for them......i really like the look of it, but hav esince gone FMIC, so i have no need for that one any more....
Old Oct 26, 2002 | 09:21 PM
BlackR1's Avatar
Meesto Spakaro
Originally posted by vudoodoodoo
WTF?!
you could buy a head of the neck!
Horizontal IC's are pretty nice. Work best with a vented hood, while allowing the radiator to remain in the stock location and achieve optimal cooling.
Old Oct 26, 2002 | 09:57 PM
if cost is your issue. try a search on NPR IC's.
Old Oct 26, 2002 | 09:59 PM
here....i searched for you. https://www.rx7club.com/forum/search...der=descending
Old Oct 27, 2002 | 05:19 PM
Ya, BlackR1
I like it too but don,t know if I am ready for a project like this..Don't want to get stuck somwhere in the middle of the project.It seems like that without vented hood there would not be enough room and flow
Thanks rxrotary
Old Oct 31, 2002 | 10:54 PM
johnchabin's Avatar
I got mine today. I have access to a machine shop and will fabricate an aluminum insulated duct. I'll keep you posted.
It looks like a well made part.
Old Nov 1, 2002 | 02:48 AM
artowar2's Avatar
johnchabin, which horizontal IC did you get?
Old Nov 1, 2002 | 05:38 AM
I was thinking of getting this one http://www.shaneracing.com/Import_Dr...rage_Sale.html
But than decided for Greddy SMIC instead.Much easier to install,and suficient for my mods.
Old Nov 1, 2002 | 07:28 AM
johnchabin's Avatar
artowar2: I got the SR 'garage sale' one posted at the top of the thread. If I decide I don't like it as a HMIC, I may move the pipes 90 degrees and use it as a SMIC. I will install it 'as is' with a custom duct and check the temps in and out.
There isn't much to making a duct. Shoot, you could rivet it together if you don't have access to welding equipment.
btytc is right, a complete kit is easier to install. But I like doing the fab work and a good deal. Gives me a Colorado winter project.
Old Nov 1, 2002 | 10:38 AM
gohorns's Avatar
I almost got it too untill I read that cooling would start at 30mph. Good for the weather right now but I dont think it can survive the Texas heat. The bad part is that I just met someone who has a welding shop and was going to hook me up with the pipes and the duct.
Old Nov 1, 2002 | 11:19 AM
johnchabin's Avatar
Yeah, I guess it depends where you are located, in the Sahara or Antarctica...
It seems the stocker or any aftermarket intercooler requires the car is moving (unless you have a fan) and I wonder at what speed they become effective (air starts to flow through the intercooler). I think most (if not all) SMIC are ducted, so the required speed for air flow is the same or similar to the HMIC. Just a guess.
Either way, it should work a lot better than the puny stock one I have right now.
Old Nov 1, 2002 | 11:45 AM
Kahren's Avatar
i am not a girl
only get a HMIC if u are gettign or have a vented hood. if u are gonna road race the car tehn get a hmic or smic. if u are drag racign or street drivin/racing get a fmic no doubt.
Old Nov 1, 2002 | 11:59 AM
Johncabin,I think you gonna have hell of a time to mount and pipe HMIC as a SMIC,good luck,its just not designed for that,but I am sure you can make it work....
Old Nov 1, 2002 | 12:03 PM
johnchabin's Avatar
I think the vented hood is only required if there isn't enough clearance on the hood side of the intercooler. SR claims there is, and I think they're probably right.
A vented hood would probably make the HMIC more effective, though (as well as a FMIC and SMIC).
Old Nov 1, 2002 | 12:08 PM
johnchabin's Avatar
This will be as a last resort if the HMIC doesn't perform as anticipated. This IC isn't that big, so I think it would fit as either HMIC or SMIC.
Cut off the pipes, weld a cover over the hole, cut a new hole, weld the new pipe. No problem.
Old Nov 1, 2002 | 05:54 PM
Johnchabin,you really want to do that?Hopefully its not gonna have to come to that.
Old Nov 1, 2002 | 07:44 PM
johnchabin's Avatar
No, I don't want to make it a SMIC. I hope it works well horizontal as planned. I just see this as a fallback. I will make this fit one way or another, as I own it now.
I guess my point is that $399 is a good deal for a new aluminum intercooler and I have the resources to make it work.
BTW, does anyone actually own the entire SR Motorsports HMIC kit (carbon fiber duct, brackets, pipes, etc)? How do you like it???
Old Nov 1, 2002 | 08:12 PM
gohorns's Avatar
John, where will you relocate the fuse box that sits on the front next to the intake? Someone out bid me ont the SMIC I was going for so I think I will get one also like you said Its gonna be better than stock. Pipes will be easy to make and no problem there but what will you use to make the duct?
Thanks
