turbo carb question
Old Jun 27, 2004 | 01:14 AM
perfect_circle's Avatar
Question turbo carb question
how much power would a 45 dcoe support on a street ported blowthrough with an s5
Old Jun 27, 2004 | 01:56 AM
FB II's Avatar
hmmm, there's a few other factors i would think. my guess would be 280rwhp?
Old Jun 27, 2004 | 02:29 AM
d0 Luck's Avatar
raysspl.com
45 might be a little insufficient, why won't you just go w/ a 55 DCOE??
Old Jun 27, 2004 | 11:17 AM
isnt 55 overkill, i was gonna use a 48 but apperently weber is on strike, and all i can find used are 45 dcoes.
Old Jun 27, 2004 | 11:29 AM
wouldnt i lose all drivability with a 55
FB II have you dynoed your nikki yet, does yours have the bog when you first hit the gas, cause i might just go to the nikki idea
Old Jun 27, 2004 | 04:44 PM
FB II's Avatar
man i just need a downpipe and i'm ready to rock and let everyone know the results. i'm trying to source out a super fuggin cheap or FREE stock downpipe for now just to get me going. i'm broke thanks to my girl
Old Jun 27, 2004 | 09:27 PM
any body use a 48 dhla?
Old Jun 28, 2004 | 02:18 PM
where can i buy a carb bonnet to put on the carb so i can turbo it b.c i have the stock nikki carb rebuilt should get a new holly carb or just stick with the nikki and where can i get all the parts like a turbo header for my 1st gen b.c i have been wantin to turbo it ever since i got it but i cant find a site or anything that offers a turbo kit for the 12a carb. and how much will the kit cost?
Old Jun 28, 2004 | 04:00 PM
coldy13's Avatar
Yeah, shutup kid.
I make carb hats for the nikki($100 + shipping), for boost prepping talk to Robert @ www.rotaryshack.com
For the exhaust manifold and turbo, it's easiest to use a TII setup, and grind the manifold until it matches the 12a exhaust gasket.
Old Jun 28, 2004 | 04:52 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Robert isn't boost prepping Nikkis anymore.
But we are.
Old Jun 29, 2004 | 12:51 AM
How much was that new custom setup on the last picture?? coldy?
Old Jun 29, 2004 | 04:16 PM
coldy13's Avatar
Yeah, shutup kid.
The Weber setup on my cardomain page? $500 for the carb, and I made the manifold for $20 in material and a lot of hours in labor. If I ever decide to make those manifolds to sell they'd cost quite a bit, probably $300-$500.
Old Jun 29, 2004 | 04:37 PM
rx_rotary's Avatar
where did you get your carb from?
Old Jun 30, 2004 | 01:38 AM
Rotor13B's Avatar
Wassup!!
There is a couple of auctions on ebay now that have no bidders for dell 48 carbs, one of them is even letting them go for 100 bucks a piece.
edit: If you buy all 6 they're 70 bucks apiece.
Old Jun 30, 2004 | 12:44 PM
yeah, but not as many people are doing dellortos, and ive also heard there arent as many places to get parts
Old Jun 30, 2004 | 01:18 PM
is any one using a dellorto for a blowthough?
Old Jun 30, 2004 | 02:40 PM
Siraniko's Avatar
RX for fun
OFF TOPIC:
OK, my 85 GSL turbo conversion is in process. MSD fuel pump is in...upgraded the soft lines to F/I rated @ 50 PSI....yes the soft lines between the tank and the hardlines. Mallory regulator is mounted
My question is primarily on the return line. The stock non-GSL-SE return hard line is only 1/4. Do you guys think its necessary to change it to 5/16? Im planning to change mine to prevent a bottle neck but before I do, I wanna hear what others have done to their non-GSL-SE FB.
Thanks.
Old Jun 30, 2004 | 02:44 PM
wacky: what carb are you using
Old Jun 30, 2004 | 03:03 PM
Siraniko's Avatar
RX for fun
mikuni 44 for now. but I would like to use a 44 ida or a holley...thats future upgrade.
Old Jun 30, 2004 | 03:09 PM
pillage6's Avatar
I can check later today on what size return I am running, I know it is the normal return line after the Malpassi regulator.
I am thinking 3/8" for some reason, but will double check later.
Old Jun 30, 2004 | 10:37 PM
Can i still use the stock nikki carb when i turbo mine and just boost up the jets to run a little richer? I have never turbo'd a car so idk what all parts i will need to buy b.c im doin what a lot of ppl said is easier in which they go to a salvage yard and buy the 2nd gen set up and shave the header to fit. Do i need to buy a bigger fuel pump to run more p.s.i of fuel or can i run it with the reg. one for a while?
Old Jun 30, 2004 | 11:29 PM
Rotor13B's Avatar
Wassup!!
You can boost prep a dell just like a weber and parts are not that hard to find if you know where to look, i.e VW buggy shops.
Old Jun 30, 2004 | 11:40 PM
RichRotorhead's Avatar
Originally posted by wackyracer
...The stock non-GSL-SE return hard line is only 1/4. Do you guys think its necessary to change it to 5/16? Im planning to change mine to prevent a bottle neck but before I do, I wanna hear what others have done to their non-GSL-SE FB.
Thanks.
When I get off my *** and do mine, I'm going 1/2 inch to and from.
-Rich
Old Jul 1, 2004 | 01:24 AM
680RWHP12A's Avatar
i just finished turbo prepping 2 dellorto 48DHLA carbs today.....so yes there is some peeps that have turbo dell. carbs
Old Jul 2, 2004 | 08:34 AM
Siraniko's Avatar
RX for fun
guys
thanks for the info on the return line.
mel
Th0m4s
Feb 26, 2019 02:04 AM
alphawolff
Nov 17, 2015 05:57 PM
pzr2
Aug 15, 2015 08:29 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
