0psi no boost checklist '91 TII
Old Sep 4, 2003 | 10:11 AM
Josepi's Avatar
Despise Enmity
All of a sudden without warning my turbo has stopped making power. Engine will idle ok. Engine revs fine. However, there is no positive pressure being made.
It'll go from 16-17" vacuum to 0" vacuum, but build no boost.
Notes:
-EMS = MicroTech LT-8 so that tosses out the stock ECU problems and pressure sensor. Doesn't need the AFM due to the MAP sensor so toss any TID idea. However I am still using the stock airbox and the AFM is in place, just unplugged to help keep boost levels down.
-3" DP/MP/N1 Dual CB so toss out the clogged cat idea.
-Timing is set and dead on.
-Fuel is being delivered...runs rich. No detonation occured prior to the turbo stopping to build boost.
What I'll be checking:
1. Turbo. Shaft play, fins, and the fact that the turbine wheel is still connected via shaft to the compressor wheel.
2. Listen for blown gaskets. I should be able to do this while in no gear right?
3. BOV. Check for function and to assure that it is closed.
What else should I put on the list?
Old Sep 4, 2003 | 10:15 AM
1FastT2's Avatar
Are you running a stock or aftermarket intercooler? Theres most likely a coupling leading from the turbo to the throttle body that is not connected properly. Even if it looks to be in place double check all of you couplings to make sure they are tight and in place.
Old Sep 4, 2003 | 10:17 AM
Josepi's Avatar
Despise Enmity
Stock TMIC. I'll go over all the hoses while i'm in there! At first glance they seemed ok.
Old Sep 4, 2003 | 01:39 PM
J-Rat's Avatar
Alcohol Fueled!
Wonder if a malfunctioning wastegate can cause this...
Old Sep 4, 2003 | 02:25 PM
Josepi's Avatar
Despise Enmity
I'd start seeing SOME boost at the upper RPMs...
Old Sep 4, 2003 | 02:36 PM
J-Rat's Avatar
Alcohol Fueled!
Only if your creeping...
Old Sep 4, 2003 | 03:01 PM
Josepi's Avatar
Despise Enmity
Adding that to the list.
Old Sep 4, 2003 | 06:06 PM
Josepi's Avatar
Despise Enmity
BWAHAHHA
I feel like the horses ***.
The IC/TB hose popped off on the TB inlet...
You see what happens if you don't touch your car for a week and let paranoia stir?!!!
Old Sep 4, 2003 | 06:22 PM
1FastT2's Avatar
Originally posted by Josepi
BWAHAHHA
I told ya so, I told ya so................ Glad you found the fairly simple prolbem.
Dont feel too bad, the same thing happened to me a couple of times.
Old Sep 4, 2003 | 06:39 PM
Josepi's Avatar
Despise Enmity
Always think the worst first right?
"Oh **** there goes a rotor..."
Jeff20B
73
Sep 16, 2018 07:16 PM
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
acha3
Sep 6, 2015 08:14 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
