Stupid Rpm Buzzer
Old Apr 29, 2002 | 10:52 AM
turboGXL's Avatar
Stupid Rpm Buzzer
Does anyone know a mod to get rid of that damn rpm buzzer. Everytime I have a girl in the car and it goes off they tell me to slow down or something, they think people are honking at me. Kinding of embarrassing
thanks
Old Apr 29, 2002 | 10:58 AM
Liquid Anarchy's Avatar
We come with the Hardcore
What's worse? Explaining to a girl what it is? Or having your radio on loud, missing a shift, and popping your engine? You shouldn't rev it that high under normal driving conditions anyway, unless you're messing with someone at a stop light, keep it below 8K.
Old Apr 29, 2002 | 11:06 AM
turboGXL's Avatar
Well normally the BIG *** tachometer in front of my face
does a good enough job of telling me when to shift. I've never heard of anyone popping an engine from over-revving, yet. Although, I'm sure some idiot has, it's not going to be me. However, I'd still like to know how to get rid of that stupid noise.
Old Apr 29, 2002 | 11:34 AM
SureShot's Avatar
Seduced by the DARK SIDE
Mine just quit by itself a few months back-- because I quit overreving it.. I want this puppy to last to 200k.
Old Apr 30, 2002 | 01:01 AM
Driftfc3s's Avatar
Final Form
so how do you disconnect it???
Old Apr 30, 2002 | 01:03 AM
RarestRX's Avatar
NA Powah, Every Hour!
Yo,
I think it's cool.
KS
1989 GTUs "Keeps my eyes on the road..."
Old Apr 30, 2002 | 01:10 AM
RETed's Avatar
Dump the girl...
-Ted
Old Apr 30, 2002 | 02:05 AM
MtnRacer's Avatar
infini guru
Originally posted by RETed
Dump the girl...
-Ted
HA HA HA HA
But seriously, I remember this topic coming up a while ago, did you do a careful search? I'm pretty sure there was an answer posted.
Steve
Old Apr 30, 2002 | 03:54 AM
Don't quote me on this, but I believe that there's a pot **** behind the cluster. You can't get rid of the buzzer, but you can turn it up so high that you'd have to be drunk or trying to collect insurence money to ever hear it again.
Old Apr 30, 2002 | 05:45 AM
2887s's Avatar
I got rid of mine on my S4 vert, I don't know if it any different on a S5. But all you gotta do is pull out your gauge cluster, unscrew the circut board off the cluster, and it will be a little pezzo buzzer that is soldered onto the circut board. I just took a small pair of dikes and clipped it off the circut board.
Mine was ******* up on me, it woulds just start buzzing (regardless of my RPM), and wouldn't shut off untill it wanted to (trust me I beat the **** out of my dash).
Old Apr 30, 2002 | 09:26 AM
Driftfc3s's Avatar
Final Form
the gauge cluster, or are you talking about the warning lights cluster?
Old Apr 30, 2002 | 09:36 AM
87turbo2's Avatar
NO the actual gauge cluster....tach, speedo, etc....
once you pull it off it will have this indented area in the middle bottom....there a little white plastic buzzer from the very depths of hell rests..... just look at the circuit bourd and I believe there are just 2 clips ( ? ) either clip them or desolder them......just take you time
Old Apr 30, 2002 | 10:25 AM
turboGXL's Avatar
Sweet!! thanks for the help guys.
Ted- It's been more than one girl though
Old Apr 30, 2002 | 11:17 AM
fastrotaries's Avatar
W. TX chirpin Monkey
I will laugh ...... the day you over rev your engine and blow your motor. Good Luck.
Old Apr 30, 2002 | 11:39 AM
Nucklez's Avatar
If you've got an 86-88 model you can just put the 89-91 cluster in. If you hit the buzzer then, you'll probably run into problems. Yes I saw the buzzer on mine, it is in a different spot depending which year you have but you can get to it on either model with the guage cluster out.
Old May 1, 2002 | 12:53 AM
MtnRacer's Avatar
infini guru
I wouldn't recommend cutting the buzzer. Not only is it used as the rev limiter, but also as a warning signal for some serious problems with your car(low coolant, exhaust temperature alarm, some of those, I think, sorry, I'm too lazy to look it up right now).
Steve
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
eplusz
15
Oct 7, 2015 04:04 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
musker
Oct 1, 2015 05:58 PM
