Help me with line locks please.
Old May 19, 2002 | 10:20 PM
Zoomspeed's Avatar
I need some help with line locks. I know nothing about them except that they lock up your front wheels so you don't roll during your burn out.
What do I need to know before I get one?
Any recomendations on one?
Are they hard to install?
Thanks for any help.
Old May 19, 2002 | 11:13 PM
jr's Avatar
jr
This should answer most of your questions - http://www.rx7turboturbo.com/robrobi...rake_valve.htm . That install is for a proportioning valve, but it would be almost identical for a line lock.
Old May 20, 2002 | 07:52 AM
Zoomspeed's Avatar
Thanks for the help, any suggestions on which one I should get?
When I use the line lock do I need to pull the ABS fuse or anything?
Old May 20, 2002 | 09:11 AM
jr's Avatar
jr
I do believe that you will need to pull the ABS Fuse in order to do a proper burn out regardless of whether or not a line lock is employed. As far as which one to get.. take a look at Summit and Jegs to see what's available. I think Hurst makes a decent one, and there are several others, they are all very similar.
Old May 20, 2002 | 01:20 PM
Zoomspeed's Avatar
another question. Do I need 2 line lock solenoids?
Old May 20, 2002 | 01:31 PM
jr's Avatar
jr
No just one. If you look at the lines coming off the master cylinder you'll see there are only two, one for the front circuit and one for the rear. You are going to splice it into the front circuit.
Old May 20, 2002 | 02:50 PM
skunks's Avatar
I'm a CF and poop smith
Im 90% sure that you can't use linelocks on a car that is still has ABS. i saw this in a JEGS catalogue i think. Can anyone confirm this?
Old May 20, 2002 | 03:00 PM
Zoomspeed's Avatar
Isn't that why you pull the ABS fuse? If you disable the ABS computer isn't it just liek haveing regular brakes?
Nosferatu
Sep 5, 2015 02:13 PM
rotor_veux
Sep 3, 2015 07:10 PM
TwentyDW
Sep 2, 2015 06:42 PM
