Keyless Entry
Old Feb 23, 2004 | 05:12 PM
rotaryhardcore's Avatar
Keyless Entry
I did a few searches, and was surprised not to find anything about wiring in a new Mazda keyless entry control module (along with a DS actuator).
If I missed it, please point me in the right direction.
Has anyone done this? Would it work, or is the control module computerized? (an '02 or '03 unit)
-C
Old Feb 23, 2004 | 05:53 PM
bigmack000's Avatar
Rotor DEMON !
umm my buddy sub-zero did a keyless set up on his fd pm him he might beable to tell you somethign
joel
Old Feb 23, 2004 | 06:22 PM
thanks...
-C
Old Feb 23, 2004 | 06:37 PM
pugg57's Avatar
proper motoring
rotary hardcore... if you are just looking for the system itself, check out jt-imports.com
they have the system from the later generation FDs.
Old Feb 23, 2004 | 08:31 PM
revsteve's Avatar
Gettin' By
or get rid of the crappy factory alarm, spend 350 bux and get a clifford RS matrix 2.5.
Has a 2 way pager system w/ the car so that when the alarm goes off, it pages the remote w/ details of why.
Also knocks down insurance w/ some compaines.
And thats 350 installed!
best buy did mine and did a great job - watch out for them though - they did my head unit too and fucked it up - i had to re-do everything
Old Feb 23, 2004 | 08:53 PM
I AM A THIEF - READ GOOD GUY / BAD GUY
revsteve: how did they remove the stock alarm? I have mine set up with a clifford but I wasnt able to remove the stock alarm and it goes off sometimes when I unlock the car with the clifford. thanks for your help.
Sean
Old Feb 23, 2004 | 08:56 PM
pugg57,
I like the OEM unit they're selling, but it's too much money.
revsteve,
Your post is funny becuase I actually have a Clifford alarm, it was installed before I bought the car. The windows roll up and down with the remote, there's a -lumi- scanner on the windshield, and a light on guage cluster; pretty cool stuff.
Sadly though, due to reasons unknown, it drains the battery if the car isn't driven every day. So, it has been disonnected and I think I'm sticking to the stock alarm, who knows what it would take to get the clifford one working right.
My main idea is to get a keyless system for around $50; simply because I know it can be done, and I'd like to keep everything as OEM as possible.
I really do appreciate your info guys...if you can throw anything else at me, please do.
-C
Old Feb 24, 2004 | 04:13 PM
revsteve's Avatar
Gettin' By
Clifford Alarm
Sean
Sean
I have no idea how they removed the factory alarm. All I know is that the guy spent like 7 hours with it trying to get it to work. Interestingly enough, I have never had a problem w/ my clifford.
if you'd like, I can get you the name of the guy who did it and you can give him a call.
PM me if you want me to do that.
Rotary - mine doesnt roll up/down the windows or have a luminescent anything on the windshield. I know I have the 2004 2.5 Matrix model. the 3.5 has a built in turbo timer and remote start - sadly, remote start on a 5-spd is illegal in Maryland.
10k fine for the person, 50k fine for the shop. Just not worth it.
Old Feb 24, 2004 | 08:53 PM
I'd definitely like to have one...
But I'm so scared of electrical stuff...I've got a bad ground that's going in and out right now
-C
Old Feb 25, 2004 | 01:39 AM
spyfish007's Avatar
Yellow Dragon is no more
To eliminate stock alarm ... ground factory hood pin. That will keep the factory system from arming. Good luck.
Old Feb 25, 2004 | 09:33 PM
Got the wiring diagram for a Protoge keyless control module...along with a module.
I guess we'll see how it goes when I get the module and go get some relays (good place to get them?)
-C
Old Feb 26, 2004 | 07:13 PM
I've read a few posts about aftermarket actuators breaking lock cables (in fact I believe mine had a breakage due to that, although the actuator was not working when I got the car).
Could I remedy this by using a Mazda OEM actuator motor?
-C
Old Feb 27, 2004 | 12:31 AM
spyfish007's Avatar
Yes if you find one that will bolt in place. Icemark gave me a give hint a long time ago. Just attach the actuator rod to the plastic door lock and not the cable and you will never break the cable. He is correct .. never lost a cable since then.
Old Feb 27, 2004 | 03:45 PM
Thanks for passing that along, makes sense though.
I've got a Mazda actuator, I haven't received it yet...but I think it's pretty small.
This is gonna be fun, haha.
-C
Old Feb 27, 2004 | 03:56 PM
ZeroBanger's Avatar
I have a thread from 6 months ago. I installed an actuator and audiovox keyless entry. Its very simple. the hardest part is bending the metal wire to the exact position. It needs to be bent so the following 3 things all work:
1) the key unlocks the coor
2) you can manually open from the inside
3) the keyless entry locks/unlocks the door.
It took a while to get it just right. Sometimes 1 & 2 worked but 3 didn't, other times 2 & 3 worked but # 1 didn't.
Old Feb 28, 2004 | 04:08 PM
I actually found that post today...great information in there:
https://www.rx7club.com/showthread.p...elay+door+lock
-C
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
BLUE TII
Sep 26, 2015 10:12 PM
