Project Kramer Dyno - 370 RWHP!!
Old Jan 25, 2004 | 10:30 PM
Directfreak's Avatar
I am a Jeeper Now.
Well,
We had a really nice time on Saturday with the
MRCCFL crew.
We had a Dyno Event, a BBQ, and a tour oss the SpeedSource shop which is building competitive RX-8's for Daytona!
I have a REALLY Good Video of my Car doing the Dyno runs, but I don't have a host that can support many users & high bandwidth.
Anyway - I did Three pulls.
1) Stock Wastegate Spring at 9 PSI = 270 RWHP
2) Boost set to 12 PSI (What I normally use) = 315 RWHP
It got a little lean at the top, so we decided to re-jet it for the higher boost runs for safety.
Then:
3) Boost set to 17 PSI = 370 RWHP.
All Done on a Holley Blow-Through system, on regular pump gas.
Here is the Dyno sheet with all three runs:
My tuner believes on C-16 (Race Gas) I could easily go to 23 PSI safely which should produce about 460 RWHP.
I think I'll try that combination at the track for the hell of it
So, who's going to host the VIDEO's?
I have:
    Old Jan 25, 2004 | 10:44 PM
    1stgen4life's Avatar
    Leaking oil like crazy!
    Wow, can't wait to see everything after you get the race gas. That is amazing. Good luck with all of that.
    Old Jan 25, 2004 | 10:46 PM
    ioTus's Avatar
    '84 5-letter
    DROOOOOOOOOOOOOOLS
    Noice dude. i cant wait to slap mine on the dyno once i get it runniN!
    theweasel's Avatar
    Wow! Great job of building a great running engine!
    Old Jan 25, 2004 | 10:48 PM
    CheddaKing's Avatar
    NICE!!
    abeomid's Avatar
    I can host the video, probably the decent one that is 15mb. Just email or pm me
    omid@bcrx7.com
    Cheers,
    Omid
    Old Jan 25, 2004 | 10:53 PM
    Rex4Life's Avatar
    RX-7 Alumni
    DF that's awesome.
    Must have a great turbo/compressor to do that much.
    Wonder if you still want to go Haltec after all that? Seems like you have something working real good.
    Scott
    Old Jan 25, 2004 | 10:55 PM
    Sudox_E's Avatar
    Wow, those numbers are amazing! I bet it feels good to have all that work done. I'm shooting for 275 on a ported 12a blow through that I should be wrapping up shortly! I wish I could/knew someone that could host your videos, Im sure theyre pretty nice
    Old Jan 25, 2004 | 10:59 PM
    hornbm's Avatar
    FD > FB > FC
    Just imagine what power you'll make once you get around to putting the haltech on there again!
    Either way, 370RWHP is pretty goddamn good, no wonder why u smoked that rx-8!
    Old Jan 25, 2004 | 11:04 PM
    I am a Jeeper Now.
    The Haltech will give more drivability, and fuel efficiency. But it will not increase HP by than 5-10% in total.
    An RX-8 with an exhaust system Dyno'd yesterday too.
    180ish to the wheels.
    Old Jan 25, 2004 | 11:05 PM
    mwatson184's Avatar
    holley guy
    or sell the haltech and buy some other stuff, seems like they holley is working just fine. I like the a/f's also.
    -Marques
    Old Jan 25, 2004 | 11:13 PM
    abeomid's Avatar
    here's the video guys/gals:
    http://www.bcrx7.com/movies/Directfreak.avi
    Old Jan 25, 2004 | 11:46 PM
    Rotofire's Avatar
    Yea, I'm working on it...
    nice, thanks but i can't see the video, all i'm getting is sound. it says i was unable to download a decompressor. whatever that means.
    Old Jan 25, 2004 | 11:54 PM
    Wargasm's Avatar
    Weird Cat Man
    What are the details on your turbo setup?
    Brian
    Old Jan 26, 2004 | 12:09 AM
    I am a Jeeper Now.
    You need the DIVX Decoder Codec from Media Player.
    Old Jan 26, 2004 | 01:19 AM
    1stRX8's Avatar
    Are you planning any races? I want to know how those drooling HP translate into speed. Post some slips or at least G-tech #'s.
    can't wait. nice going.
    Old Jan 26, 2004 | 01:48 AM
    NanaimoRx-7's Avatar
    UNF UNF UNF.
    That's awesome man....can wait to see what that thing can do.
    Old Jan 26, 2004 | 02:27 AM
    Chemical's Avatar
    I wonder what 370 hp feels like in an FB..
    thx for the vid
    Old Jan 26, 2004 | 03:02 AM
    luiml73's Avatar
    Rotary Powered Boobies
    Great vid Alex. That was a pretty good turn out at the BBQ.
    I'll PM you the links of the wheels for your widebody
    Old Jan 26, 2004 | 05:22 AM
    someone82's Avatar
    Bitchin' dude.... It's awesome to see some real numbers from a turbo'd wankel... Great job!!!!
    only one day I hope too see the same numbers from my car...
    matt
    Old Jan 26, 2004 | 05:58 AM
    inittab's Avatar
    I read your email
    Truely amazing! I bet it feels great to see the actual numbers. I can't wait to see the vids.
    Originally posted by Directfreak
    An RX-8 with an exhaust system Dyno'd yesterday too. 180ish to the wheels.
    The problem with dynoing an RX-8 is that the computer senses front wheels aren't moving and puts the engine into "limp mode". I don't know if anyone has figured out how to bypass this little problem.
    Old Jan 26, 2004 | 06:05 AM
    RotorMotorDriver's Avatar
    Seven Is Coming
    **** DF, I just wanted 350 RWHP on my project... Ya think I could pull that off with a blow through setup also? I was JUST thinking last night about going blowthrough for "simplicity" to start with (like ioTus), maybe using a DCO carb though, then later when I can afford it switching it out for an EFI throttle body. I would still run a stage 2 turbo and stuff, but do you think I could pull off 350 with a blow through stock port 13BT and modded turbo?
    ~T.J.
    EDIT: Heres what the site says about the turbo I plan on getting:
    Stage 2 Mega Hi Flow S4/5:
    .50 Comp cover and back plate fitted
    V trim front wheel
    T04 exhaust wheel
    Full recondition
    These units are the ultimate in bolt on horse power , they feature a T04 exhaust wheel/shaft , a T66 front cover , E-trim wheel and larger integral waste gate. Good for 240 + rwkw, they bolt on to the existing exhaust manifold and are good for low 11's to hi 10's in a well set up early Mazda.
    Old Jan 26, 2004 | 09:03 AM
    I am a Jeeper Now.
    The Video is being Hosted by ABEOMID, see further up at his link.
    They have, it still goes into limp mode, but not until you get the runs in.
    Old Jan 26, 2004 | 09:56 AM
    inittab's Avatar
    I read your email
    Got it... I shoulda said... I can't wait to get off this damn modem and onto my office's T1 so I can download it.
    Can you explain further? links?
    Thanks
    Old Jan 26, 2004 | 11:40 AM
    coldy13's Avatar
    Yeah, shutup kid.
    Great video, nice server too, 260k/sec average.
    Mine's only making about 225-250rwhp now, can't wait until I put on the weber, T04B, and the intercooler. Oh yeah, the new dowel pinned and streetported 12a might help too Hopefully I'll be able to put down a bit more power then.
