Argh I think I popped it!
I think I blew a seal last night I was out driving around got on taking off from a stop sign shift in to third and felt a hesitation. came to a stop at the then next stop sign idel sounds real lumpy bring it home park it in the garage check afew things outnothing I can see. hoping was fouled plugs changed those a few minutes ago still lumpy idel and when boosting the needle doesn't move smoothly any more kinda shakes as it builds up. *****.
where should I take it or what should I do total loss it right now.
mods are:
Apexi Power fc
" gt spec exhuast
" intake
" bov
downpipe
midpipe
greddy under drive pulleys
mods are:
Apexi Power fc
" gt spec exhuast
" intake
" bov
downpipe
midpipe
Try to read the tread about how the map sensor can make your car seem like you blew your motor.
If you have a compression testor kit, that's the thing i would check first. especially when you were changing out the spark plugs.
Did you have your power FC tuned correctly and what boost are you running??
Good luck.
Good luck.
Try reconnecting the map sensor and if that isn't it I would do a compression test. My friend had a similar problem...ended up that he cracked a coolant seal and it only took a little more time before it totally blew
Isn't there sort of a crude compression test? pull the plugs, and crank, listening for pop, pop, pop... etc... Well the "pop" is the build of compression, so if it doesn't sound like a distinct pop, it isn't making good compression. If you get one pop out of several, that's indicative of a blown apex seal, whereas if you get no pops out of one rotor that's a corner/side seal, right?
1JZ powered
you can pull either plug really, doesn't totally matter.
make sure u see about 250rpm when cranking, or the battery is still good.
you can buy a regular compressin testor kit for piston motors for 20 bucks. Just use it and hold the peak hold button down. You should see the needle jump 3 times pretty fast. Just see where they roughly were. I think you want about 120psi+???.i forgot.
danny
danny
Trending Topics
1JZ powered
Originally posted by nocab72
What is your boost gauge reading @ idle?
K
K
I noticed the midpipe in your mods list. Is your wastegate ported? What boost do you creep to, if at all? Are you running stock injectors, and what kind of peak inj. duty cycle are you seeing at 8k WOT in 3rd gear?
Never had any boost creep had it set to .80 of a bar never took ot to 8k rpms always shifted at 7k tops won't have time to pull the plugs agian this week have three pools to build going to have to make an appiontment at mazduh and see what happens if it still has good compression (not fuggin likely) i'll have them check the coils and map sensor don't it gets past the compression check. Argh this month blows.
at 7k I usually seen about 88-89%. and the wastegate isn't port as far as i know Ididn't do it or have it done but I noticed when I took of the percat some had cut it open guted it and weld it back together.
ls1swap
Jun 3, 2024 03:25 PM
renjiv2
57
Jan 25, 2024 03:34 AM
poop2003
Sep 21, 2015 10:28 PM
