New Clunk. Front diff mount??
Old Feb 13, 2012 | 03:08 AM
monkey1911's Avatar
WA New Clunk. Front diff mount??
Picked up a clunk yesterday on the way back from the store. sounds like it's centerline about a foot-ish behind the drivers seat. Clunks on accel or decel, but it's louder like it's hitting the body on accel. I'm thinking the front diff mount gave out, what says the hive mind?
Old Feb 13, 2012 | 04:16 AM
dwb87's Avatar
This is my social media.
It's probable. Jack up the car and take a peek. If it is broken, replace it and install a pinion snubber. It will definitely help. If you feel like driving up to south Bellevue, I'll give you a snubber.
How to: Pinion Snubber Install
Referance pics
Old Feb 13, 2012 | 04:27 AM
monkey1911's Avatar
That was the plan, but I won't have time off to take care of it until next weekend or maybe the weekend after that. LOL. Sometimes I have my work schedule!!!
Old Feb 13, 2012 | 11:40 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Very likely the front diff mount if it clunks on abrupt accel/decel. You'll have a hard time avoiding it on 1-2 and 2-3 gear shifts, as well as any downshifts.
My writeup: https://www.rx7club.com/2nd-generation-specific-1986-1992-17/pinion-snubber-diff-mount-replacement-convertible-876959/
It can be hard to tell visually that the mount is sheared. Grab a pry-bar, and try to raise the pinion up. If it moves, but the mount doesn't, it's done.
Old Feb 14, 2012 | 12:35 AM
Elgonidas's Avatar
Also be prepared for the possibility of this... Happened to me.
Old Feb 19, 2012 | 05:17 PM
monkey1911's Avatar
I blame you for this!!!!!! Mine isn't ripped out quite as bad as yours, but it is ripped. Off to find a new subframe now.
Old Feb 19, 2012 | 08:33 PM
bumpstart's Avatar
talking head
helped fix one just like that yesterday , bit of SS plate drilled and cut with slots and welded a bead at the top
sized to fit inside what remains of the mount and gusseted down both sides and along the bottom with the mig
this remakes the frame though is 3mm more outboard and so you put a spring washer on the inside between the studs and the new plate
Old Feb 20, 2012 | 10:29 AM
Elgonidas's Avatar
Yep. i took down my subframe and had a friend weld it up for me.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
fidelity101
13
Aug 31, 2015 07:47 PM
