FB Vented gas cap???
Old Jan 5, 2012 | 01:18 AM
rotorican85's Avatar
rotorican85
Anyone know where i can get one? the only i found that fits the fb is too tall and does not let the gas door close properly. i need one vented since i have modded my tank and i dont feel safe leaving an open vent underneath the car, so i'd rather use a gas cap that properly vents the tank. thanks for input!!
Old Jan 6, 2012 | 02:24 PM
DreamInRotary's Avatar
Always Wanting to Learn
http://www.blackdragonauto.com/icata....aspx?page=115
Here is one that I found through Black Dragon Auto. It is a locking one, I am not sure if it is vented or not. You could give them a call. This might also be another one that is too big. Just for you to check out.
Old Jan 6, 2012 | 02:31 PM
http://www.autopartswarehouse.com/mm...cap~parts.html
Another page of some for consideration
Old Jan 8, 2012 | 01:13 AM
NCross's Avatar
I have a rotary addiction
The rest of us just open vent after removing the charcoal canister and whatnot.` Just run a hose down the side of the tank to a mini air breather filter if you want.
Old Jan 8, 2012 | 02:11 PM
rotorican85
Thats the only option i got left. The height of vented caps doesnt let the gas door close properly. Any suggestions on breather boxes? I was thinking of a small crankcase box commonly used in the vw crowd.
Old Jan 9, 2012 | 12:16 AM
NCross's Avatar
Use a charcoal canister? Or a check valve with a mini breather filter on it.
Old Jan 10, 2012 | 10:43 AM
cyipher's Avatar
drill a pin hole in your current cap?
Old Feb 9, 2019 | 09:52 AM
Johnny_Cracker's Avatar
irritating nuisance
I know I'm totally necroing this thread but I tried this and it works but if you corner hard and petrol sloshes up the fill neck the vapor pressure will spurt gasoline out the pinhole and it'll run down the side of the car. I drilled like a 1/32 hole and this is what happens to me. I need to find out where the stock vent setup is clogged..
Old May 3, 2020 | 08:57 PM
Walldog's Avatar
Johnny you ever figure this issue out? I have same deal on my SE. I've drilled hole in cap but sure enough gas all down side of car now. Curious your results..
Thanks
Old Feb 5, 2021 | 04:41 PM
gagnon.shane's Avatar
Old School
Ddi anyone ever come up with a simple gas cap tank venting remedy. I installed a mikuni 44 carburator on my 12A, and in Arizona the heat pressurizes the gas tank and pushes fuel past the Carb needle float and fills the carb bowls then out the throats. Does anyone know if they make a mini one way bleeder valve that can be adapted our cap?
Old Feb 5, 2021 | 10:57 PM
JOE68's Avatar
theres a vent on top of the gas tank .. u will see hose going to what looks like a round ****..assuming its a 83 to 85 12a .. never leave my car stock. , i have a pcv valve and a small filter on my rx vents just fine
Old Feb 5, 2021 | 11:05 PM
JOE68's Avatar
sometimes old stuff stops working probably
Old Feb 5, 2021 | 11:09 PM
JOE68's Avatar
good luck
Old Mar 7, 2021 | 12:46 AM
Holdfast's Avatar
HoldFast Rotorsports
Tenured Member: 5 Years
On my mikuni I ran a tee on fuel inlet. To a return to the tank with a check valve on the return. Carter 4070 pump and a low pressure regulator from aeromotive that was made for Weber's. Regulator was expensive. But only one that worked with that carb. Pressure set at 2.5 or 3. I had same problem with pressure creep. It ran hard with that set up. Wish I didn't sell it.
Old Mar 7, 2021 | 09:06 AM
t_g_farrell's Avatar
Waffles - hmmm good
Your vent tube is clogged or the hose is clogged at the check valve under the car. Just run the vent to the nipple on the center iron and the run a pcv valve from the nipple on the oil fill tube into your air cleaner, problem solved. Thats what I have and no whooosh when I open the cap.
Cincy7
22
Apr 27, 2022 08:47 PM
mjm4jc
Nov 14, 2009 03:08 AM
GrndSprtZ
Dec 3, 2003 11:17 AM
