Starting issue
Old Oct 23, 2011 | 05:53 PM
vincentrx7's Avatar
Starting issue
Lately my car has to be turned over about 3-6 different times before it starts. I have 3 fuel pumps and a relay for each. I've noticed that the relays drop out and the pumps shut off while the engine is turning over. The fuel pressure drops off and it won't start after 3-6 tries. I guess after enough tries, I have enough fuel to fire off.
I checked the voltage and it drops off to like 9.x while cranking and that is enough to drop out the relays. I checked several different hot wires while cranking and get the same voltage.
I wonder if the starter is going bad and drawing down the voltage too much?
Any suggestions?
Old Oct 24, 2011 | 05:17 AM
Banzai-Racing's Avatar
Rotary Specialists
How old is your battery? Hook it up to a charger and see if it helps the issue.
Old Oct 24, 2011 | 07:10 PM
vincentrx7's Avatar
Battery not too old. I did charge it before trying to start it recently. I can try starting with the charger though. Thanks.
Microtech
30
Apr 23, 2016 06:37 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
FB_Frank85
Aug 31, 2015 03:31 AM
befarrer
Aug 14, 2015 04:18 PM
