driveline
Old May 31, 2011 | 12:11 PM
TurboHooker's Avatar
Rx Mike
driveline
Rear end clunk my 84 rx7 has a clunk in the rear end still drives fine but clunks any suggestions
Old May 31, 2011 | 01:01 PM
rxtasy3's Avatar
at what time does it make this sound? during acceleration? deceleration? when turning? going over bumps?
Old May 31, 2011 | 02:23 PM
kutukutu1's Avatar
give us a bit more info on when it happens, back when i bought my 7 it had a clunk and a wooshing sound at high speeds, it turned out i was loosing the bolts that held the ring gear on the differential and i was eating them up, that was the clunk. when i pulled it out i had one bolt left. pull the diff and inspect it.
Old Jun 1, 2011 | 06:54 AM
Rx Mike
It happens while I accelerate and decelerate what happens was I went to do a pull in 3rd and I got to about 90 and it started humongous real bad then it started clunking it seemed to be pulling harder on one axle then the other I'm pulling the different today after work
Srry humming
The diff my phone is being a peace of ****
Last edited by mar3; Jun 4, 2011 at 01:24 PM. Reason: Merged back-to-back to posts prior to move back to correct New Member tech section...
Old Jun 1, 2011 | 10:29 AM
kutukutu1's Avatar
that sounds like its time to rebuild your diff. by the way if you can pull the complete live axle out its going to be much easier to put the diff back on, unless you have a lift. its pita to put back on, ive pulled mines twice trust me.
Old Jun 1, 2011 | 06:54 PM
Rx Mike
Shredded some of the teeth on the pinion so knw the next question where can I get a set of gears been looking but no luck?
Old Jun 2, 2011 | 11:34 AM
kutukutu1's Avatar
maybe you can get one from a member, ask in the for sale section
George84
Sep 28, 2015 11:58 PM
RedFD
Feb 25, 2003 11:09 AM
hornbm
Dec 7, 2002 06:01 PM
Manolis_D
Nov 18, 2001 01:03 PM
