removing injector diffusers
Old Jan 25, 2011 | 01:48 AM
AchillesGr's Avatar
hi guys,
i pulled my motor for rebuild and i am thinking NOT to install injector difusers.
i hear that becomes britle and breaks over the time.
is that making sence?
does this affect the injector sealing?should i remove them or break only the legs and install the uper body only?
how many of you had them removed?
do you experience any problems?
thanks
Old Jan 25, 2011 | 02:03 PM
Radial GT's Avatar
*BOV sound*
Replacements come in the oem gasket kit. They are needed to be there for the seating if the injectors
Old Jan 25, 2011 | 02:58 PM
Mahjik's Avatar
Mr. Links
Originally Posted by AchillesGr
should i remove them or break only the legs and install the upper body only?
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/fuel-system-upgrade-how-write-up-kgparts-kit-404091/
Old Jan 25, 2011 | 03:05 PM
AchillesGr's Avatar
thanks!
Old Jan 26, 2011 | 01:05 AM
twinsinside's Avatar
They'll last longer than the engine, but yeah you should put new ones in. If it wasn't for the o-ring part of it needing replacement you could probably reuse ones from old engines.
Old Jan 26, 2011 | 08:44 AM
RXtacy's Avatar
I'm the Juggernaut BITCH!
Howard Coleman just lost an engine due to his diffusers deteriorating just a thought.
https://www.rx7club.com/showpost.php...&postcount=337
https://www.rx7club.com/showpost.php...&postcount=346
https://www.rx7club.com/showpost.php...&postcount=349
Old Jan 26, 2011 | 08:54 AM
They definitely do NOT always last longer than the engine
I personally have torn down three engines over the years that were destroyed from the brittle old plastic breaking off and getting sucked into the intake port. Needless to say, we replace (if original--side feed injs) or delete (top feed injs) these little guys on every build.
Old Jan 26, 2011 | 11:00 AM
AchillesGr's Avatar
ok.
i have the OEM side feed injectors for now.how can i install the injectors without the diffusers?
can someone please describe how i install the secondaries and the primaries without difusers?
Is the head of the difuser with broken legs necesary?
the same apply to both primaries and secondaries?
thanks!!
Old Jan 26, 2011 | 05:08 PM
Ok ok I stand corrected, but that's still pretty rare I would think
Old Jan 26, 2011 | 05:42 PM
G's 3rd Gen's Avatar
I have my engine torn to the short block and and they broke into several pieces after barely touching them w/ 20k on the build. Those lil suckers are expensive!
Old Jan 26, 2011 | 06:59 PM
Lightbulb
ok.
thanks!!
Why not just purchase new ones? They're not cheap, but will last you another 15 years or so.
Hoo-rah. Still not odds I wanna play with
Old Jan 26, 2011 | 07:11 PM
LoL I'm not suggesting he re-use them, especially since the sealing part of them is going to be trashed anyway.
They're so easy to damage even brand new that its possible they were cracked while being installed, leading to them failing later on.
Three out of probably the hundreds of rebuilds you've done (or more) ain't bad. Aren't they made out of some kind of ceramic or something?
Old Jan 27, 2011 | 01:38 AM
AchillesGr's Avatar
hi,
so , buy new ones and break the legs?
this aplly to all four or only the secondaries?
when top feed injectors are installed is anything of these difusers and seals needed?
thanks!!
FD7KiD
15
Feb 26, 2021 10:12 PM
imitek
Aug 28, 2015 05:28 PM
FD7KiD
Aug 17, 2015 11:50 PM
