excessive smoking
Old Jul 5, 2002 | 12:50 PM
Newbie
Angry excessive smoking
HELP! 88 RX7 63,000 original miles, no problems, just started excessive smoking(greyish haze) and oil consumption.Manual says metering pump &/or nozzles?
If not this, internal problems? do you agree?note:car still runs ok
Old Jul 5, 2002 | 01:32 PM
biorotary's Avatar
when does it smoke (when you start the engine, all the time while car is running, etc)?
where are you at in ca?
did you just get the car?
did you do any work on the car?
Old Jul 5, 2002 | 02:35 PM
Newbie
about 1 min after you start, increasing rpm's 1000 to
3000 parked and under hard acceleration. Northern L.a.County, just got the car in May from family, sat off and on for 1.5 years, smog test only and brakes.Thanks
Old Jul 5, 2002 | 03:04 PM
darkwaveboi's Avatar
Need donor car in Fairfax
may be an oil seal since it sat for so long and you said it was consuming oil a lot...but the smoke is gray?
Old Jul 5, 2002 | 03:23 PM
nitroracer's Avatar
Dub'N
my 7 does it alot. when ever my car is cold and i start it up it smokes alot , then it gose away after it warms up...it smokes like crazy!!!
Old Jul 6, 2002 | 02:21 AM
Newbie
update
Thanks to all who have responded. Heres more info on problem.
1. idle to 2500 rpm- off and on Greyish smoke
2. stop and go driving occasional burst of blue-grey smoke
3. freeway speeds 65-85 smokes under deacceleration and steady speeds (eases up under acceleration temporarily)
DO I disconnect manual arm to pump and run pre-mix to see if problem goes away?
DO I have internal problems APEX seals?
Car has good power, oil psi is 30-35 @900 rpm at idle. Goes up to 60+ under driving conditions.
Thanks again.
Old Jul 6, 2002 | 07:50 AM
Sounds to me like your turbo seals are gone...
Dont freak out to much, it shouldnt cost you the earth to fix. Mind you the turbo will have to come out and be sent to someone that rebuilds them. Get it highflowed while its out!!!!
Im sorry , but I dont know of were to go over there to get it fixed. I live in Australia..
You can check to see if your oil metering pump is dumping to much oil in by pulling your plugs out and having a look at them to see if they are gumbed up. If they are realy old plugs you might want to think about replacing them and go for a drive and cheak them afterwards.
Old Jul 6, 2002 | 09:28 AM
Do you have a turbo ? turbo won't be the problem IF HE DOESNT HAVE ONE
your problem is your oil control rings....
go ahead and try disconnecting your OMP control arm and running premix.. but you will have the same results most likely..
the seals probably just wore out from sitting so long....
rebuild is only fix if that is the case.... Do it yourself cheaper, funner, and you learn more about rotaries
Apex seals would have no affect on burning exessive oil..
Old Jul 6, 2002 | 09:19 PM
mmm, ok. So he dosent have a turbo... whoops... er sorry.
We dont have many N/A RX7's here...
Old Aug 7, 2002 | 12:45 PM
nitroracer's Avatar
Dub'N
i need to fix the same problem with my car too...
ls1swap
Jun 3, 2024 03:25 PM
mulcryant
Oct 4, 2015 12:18 AM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
