No Spark
Old Jan 16, 2011 | 07:17 PM
ihavetwins's Avatar
Needs more seat time
IL No Spark
Did a half *** search decided to just ask.
So here's the problem.
Car will not get a spark. However when i push start it i will start right up. For a while i was having a hit or miss when i tried to start the car using the key. I would crank it and nothing come back the next day car will start right up.
the other day wasn't so cold so i pulled the wire and had a friend crank it.... I used my self as ground haha. However i didn't get shocked so no fire. lol
Mods are.
Single swap with all the support.
I have pretty much Stock Ignition. just put in new NGK 9's all around with Magnacore 10mm wires andT2 Coils.
I replaced the Ignitor thinkin it would be it.(SP?? igniter) still nothing. at least i have a spare now....
any idea's ?
Old Jan 16, 2011 | 07:18 PM
ihavetwins's Avatar
Btw starter is fine.
Old Jan 16, 2011 | 07:20 PM
Mahjik's Avatar
Mr. Links
Question
Are you running an ignition amp with the T2 coils?
Old Jan 16, 2011 | 10:27 PM
ihavetwins's Avatar
No
Old Jan 16, 2011 | 10:46 PM
Mahjik's Avatar
Mr. Links
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/how-install-fc-leading-coil-into-fd-260205/
Old Jan 17, 2011 | 10:42 AM
trainwreck517's Avatar
Rx-hippie
I Had a similar problem, the ECU wasn't get an RPM signal (No RPM reading during cranking on the PFC). Car would fire up sometime, and wouldn't others. What I did was simply move the pulley sensor (not sure what's called, thing that reads engine position.. similar to Crank Angle Sensor function) closer to the pulley ring. I just added two small washer behind the sensor to narrow the gap between the sensor and the ring on the main pulley. After that, never had a problem since, and been over 3 years now.
Hope that helps.
Prediict
32
Nov 18, 2015 08:41 AM
Aramir
Oct 18, 2015 02:39 AM
tctwaites
Sep 22, 2015 08:48 PM
