Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
Stock port renesis dyno'd
Old Dec 16, 2010 | 11:18 AM
Rub20B's Avatar
Exhaust Manifold Leak
Hello,
We're running a 6port renesis in a miata for circuit racing, a while ago I did some testing on the dyno.
First graph is with the APV and VDI at stock opening points (6000 and 7250rpm), SSV is always open
Second graph is with the enhanced rpm points 6250 and 7750rpm, and with the airfiler removed. I wanted to roll in the run as the injector staging was doing weird things at 3800rpm
the last graph is with the enhanced points and with the airfilter back on..
it's running on a kdfi/MS2, LS2 coils, stock plugs, no split and a DIY exh header
afr's are in the high 12's for those interested, I have logs from the runs.
Attached Thumbnails Stock port renesis dyno'd-1.jpg   Stock port renesis dyno'd-2.jpg   Stock port renesis dyno'd-3.jpg
Old Dec 16, 2010 | 11:52 AM
t_g_farrell's Avatar
Waffles - hmmm good
Need a translation
Old Dec 16, 2010 | 12:23 PM
Rub20B's Avatar
Ah ok,
The firstpower is corrected power, which is the power at the wheels+rolling resistanc x correction factor calculated per DIN 70020 with the measured data at the right hand side
the second power is the power at the wheels + rolling resistance
third is power at the wheels
fourth is peak rolling resistance
below you find peak troque
so vermogen : power
koppel : torque
anyting else
Old Dec 16, 2010 | 01:47 PM
sen2two's Avatar
Rx2 > FD
I remember when you first posted about this years ago on No Pistons.
Old Dec 16, 2010 | 02:00 PM
Rub20B's Avatar
yep, by then it wasstill the idea to run a carb, but I learned about carbs with the small 250cc kart engine and E85, and since then I hate carbs so we went efi, and until now the renesis is going strong, too bad there's snow now here, otherwise we would have raced it at zolder this weekend
Old Dec 28, 2010 | 01:16 AM
pdxhak's Avatar
So wielvermogen basically means wheel horse power? The higher numbers on the graph are adding in the calculated drivetrain loss?
Old Dec 28, 2010 | 03:32 AM
Rub20B's Avatar
Thats correct yes.. the inertia of the dyno is known, so after the run you press the clutch and put the car in neutral and let is roll out, tis way it calculates the drivetrain loss, wich is the green line, around 45hp seems normal at 200kph, it's a dyno with 2 small rolls and a 14" miata wheel..
Old Dec 28, 2010 | 12:41 PM
Jedi54's Avatar
Jedi M A S T E R
wow, very cool project.
Old Dec 28, 2010 | 12:52 PM
Rub20B's Avatar
I'm still awaiting pics and video of the dyno.. seems to take forever.. in the meantime, here's a photo from the the exh manifold tacked up..
Old Dec 28, 2010 | 05:14 PM
rotarygod's Avatar
Rotors still spinning
Originally Posted by t_g_farrell
Need a translation
The simple translation is "it makes more power than the 13B that everyone thinks is so superior to the Renesis" LOL! Turbos don't count btw!
Old Jun 21, 2011 | 03:59 PM
Rub20B's Avatar
Small update, engine is in the car and running very well. Tuned it around 13.2:1 in the midrange, top end is still slightly on the rich side at 12.5:1
EGT's half a meter after the end of the 3x1 collector peaks around 915°C during track use. I am wondering if I could be runnign too uch advance? I was running around 27° midrange and 25° top WOT, 98oct fuel.
But overall the car is performing very nice, and as we speak I am uploading a onboard video from a trackday last week.
One problem remains and that is the oil temperature, it stabilizes in the 140-145°C on track, this is with 2 turbo II coolers with thermostat blocked put parallel and in the airflow. Oil pressure is regulated to 5.5-6bar
Attached a pic of the ghetto style pressure regulator, picture of the ghetto style car and a link to a datalog; youtube video will follow!
Grtz
Ruben
Attached Thumbnails Stock port renesis dyno'd-15062011512.jpg   Stock port renesis dyno'd-21042011474.jpg
Old Jun 21, 2011 | 04:46 PM
PDF's Avatar
PDF
That sounds ok timing wise, but I suspect you may want more than that. RENESIS rotors require more ignition timing than earlier rotors due to the poor combustion chamber shape. If the ignition timing is infact less than optimum for the engine it can result in higher coolant and oil temps, oil being the harder of the two to control. Even an earlier engine with stock or street porting wants 30 degrees or more ignition timing. However this is not taking into account VE, which I suspect is better in the RENESIS engine.
The best way to set the timing is too keep advancing it on the dyno 2 degrees at a time until power starts to drop, then move it back to where peak power occurred and fine tune the AFR if need be. This is where the engine is happiest and most efficient, which generally results in the least heat transfer to cooling systems.
One more thing to note - because of the higher compression ratio and the thinner wall thickness of RENESIS rotors, they do require increased oil cooling capacity. This is confirmed when RENESIS rotors are used in earlier engines. There is a significant increase in oil temps.
I think at 140-145C it will not be long before you run a bearing. Use a good quality FULL synthetic oil, if you are not already, and be sure to change it after every meeting until you can bring oil temp under control.
I'm curious as the theory behind your header design, can you elaborate?
Old Jun 21, 2011 | 04:59 PM
arghx's Avatar
rotorhead
A few months ago I had a PM conversation on rx8club.com with a guy who was racing Grand AM in the USA. He mentioned that when his exhaust temps exceeded about 900C/1650F (due to lean fuel-saving tune) he would get premature side seal failure (happened on multiple engines). I'm not entirely sure where that temperature was measured. After a lot of testing he was settling on a lambda of around .82 which is richer where you are at. This gave a good power and kept EGT under control. I'm not sure what timing he settled on eventually but I know his max leading advance at one point was about 36 degrees by redline.
This was a 100% stock Renesis. I believe his fuel was US 93 octane (until he later switched to race fuel) which is like European 98 RON.
If it's any help, at WOT stock Renesis will ramp up to 30 degrees leading at redline with 15 split.
y axis is a load calculation related to the MAF sensor grams/sec airflow reading as opposed to a manifold pressure reading.
Attached Thumbnails Stock port renesis dyno'd-rx8_timing_leading_oe.jpg   Stock port renesis dyno'd-rx8_timing_split_oe.jpg
Old Jun 23, 2011 | 02:31 AM
Rub20B's Avatar
AR
Hmmz, I was told by an experienced rotary builder from the US that they tuned the PP engines to high 13's afr wise and 20 degrees advance, egts well exeeding 900 degC..
So it seems I will be trying more advance and sligtly more fuel in the midrange.
About the oiltemps, it understandable that these rotors put more heat in the oil, but I am using 2 turbo II oilcoolers and still facing this temps..:/ oil is total/elf quartz racing 10w50. In the datalogs the oil pressure doesnt drop below 5bar at normal rpms.. I'm quite satisfied by the sucky rx8 oilpan design/pick, even after 3-4 seconds of more than 1.1 lateral G there isnt the slightest drop in pressure. This is with the stock small rx8 oilpump.
What is quite strange is that even with warm engine I still measure up to 5 bar pressure drop over the coolers which are in parallel), so before coolers it can make around 10-11bar before the pressure relief in the front cover opens.. when visually looking into the coolers they look new on the inside
For the headers.. There is no real theory behind it, the main objective was flow and I had to deal with packaging constraints, as the engine is completely behind the steering rack and also as low as possible in the car, there was extremely little space to make a equal length manifold.. I was thinking as this engine has no overlap as to speak of, a tuned manifold would not give gains like one would expect on a PP-engine. We also using the stock rx-8 muffles as we have 95 dB limit on track.
here is the first part of the incar move
http://www.youtube.com/watch?v=EFxu4JkSdlA
Old Jun 23, 2011 | 03:56 AM
Rub20B's Avatar
Big thanks for posting the stock timing maps.. U must say I am running no split atm as I spent 2 days trying to be able to run split with my ms2, it worked in the beginning then I updated the firmware and after that, whatever I tried when I chose fd and rx-8 mode only 2 ign outputs were operational. what I must also say if that if I run the timing from this map at idle it doesnt run so smooth, it misfires in the exh now and then, now I put it around 0 degrees at idle and there it seems to be fine, running around lambda 1 (slightly lean as otherwise the eyes start to tear when it idling inside from the HC's :p)
Do you think it would be knock sensitive to run this timing map witout split?
Here's part @ of the run
http://www.youtube.com/watch?v=rsEMTn7X5xg
Old Jul 5, 2011 | 09:54 AM
SaveTheRx-7's Avatar
Save the rotary engine
Rub20b, can you share some info or a link on how the Renesis installation into the Miata was done? I am trying to do kind of the same install on my nb Miata all motor project car.
If anybody know a thread showing the install on a nb Miata please post back. Thanks
Old Jul 13, 2011 | 01:04 PM
Rub20B's Avatar
Will try to post some good fotos after the weekend. I instlled the engine as low and far back as possible, because it is mounted the same way in a rx8 this was a good case for shifter position and offcourse weight distribution of the car (should be as I havent had it on the scales yet)
Here's a quick snap of the 2 TII oilcoolers, the bottom one has a small duct, the top on touches the bottomside of the radiator and the topside of the bottom oilcoolerm so if is actually a closed box, and all the air that enters has to pass trough one of the oilcoolers or the water radiator
Old Jul 13, 2011 | 03:20 PM
t-von's Avatar
Rotor Head Extreme
Interesting way to mount that 2nd gen cooler! I originally had my radiator staked on top of my 2nd gen oil cooler as a cheaper way to get things running. Now I'm gonna go with twin 25 row units instead.
Old Jul 14, 2011 | 01:16 AM
Rub20B's Avatar
I was optiong for the earl's 60 row, medium width, and do like a V-mount with the radiator.
I am a bit concerned to go for dual sidemounts in case of a light crash or hit on track
Old Nov 14, 2011 | 03:59 PM
Rub20B's Avatar
Small update.
Oilcooler is installed, its the ealrs 60 row in a Vmount setup, seems the 2 TII oilcoolers in parallel where really restrictive as now I see a nice 6 bar of pressure from cold idle till warm, warm idle is still only about 1.5 bar, but thats fine for me
Quite some time ago I got in on the dyno once more.. made less power now, altough we had to change the muffler system a bit more (due too noise constraints) which I think apart from being another dyno is the main reason for this.. I found out the engine seems to make the best numbers at around 13.2:1 afr, and ign timing doesnt have a huge impact..
We are now quite a bit earlier with timing than before
Dont have plots on this atm, altough when I dont forget I'll post them
Old Nov 14, 2011 | 04:33 PM
lastphaseofthis's Avatar
My job is to blow **** up
....when his exhaust temps exceeded about 900C/1650F (due to lean fuel-saving tune) he would get premature side seal failure (happened on multiple engines). I'm not entirely sure where that temperature was measured. After a lot of testing he was settling on a lambda of around .82 which is richer where you are at. This gave a good power and kept EGT under contro
the failure, is the side seal SPRINGS, which are a NOW-known failure point in the Renesis motor, with lean tunning, thats does NOT appear in any other 13b engine, for one simple reason, the renesis is the only one with side exhaust ports, thus the hot exhaust gases cause the spring the fail. just an extra something to think about. the good new is, side seal springs are cheap enough, you can fix it later when it turns into a huge problem.
Old Nov 14, 2011 | 04:55 PM
rotarygod's Avatar
I wonder if anyone has doubled up the side seal springs in a Renesis like some people use to in the 13B?
Old Nov 14, 2011 | 05:02 PM
There was a thread on the 8forum, where Eric Meyer, likely the source of this info, has tried that, and a few other countermeasures with no avail.
EGTs>1650 F=failed seals. i know someone will laugh at this but, what about water injection on an N/a? even a 100cc dribble would bring the temps down eh?
Old Nov 14, 2011 | 05:17 PM
rotarygod's Avatar
I wouldn't laugh at that idea at all. I've speculated about it but have never tried it.
Old Nov 14, 2011 | 05:24 PM
RotaryEvolution's Avatar
Sharp Claws
i would tend to think that water injection would help bring the EGT's down even with a small amount. would have to run slightly rich on the premix to compensate though.
atkins also makes cryo treated side seals which may help somewhat.
the PP exhaust side seals take a bit of abuse in the renesis. keep in mind they are taking all the heat from the exhaust gases and then cooling rapidly during the intake stroke, well attempting to anyways.
