7 smokes on startup and when at high boost
Old Jul 1, 2002 | 05:57 PM
RavenRx7's Avatar
Unhappy 7 smokes on startup and when at high boost
Hello all,
I have a 93 with a rarely new motor but the turbos on it are at 104k. I was pushing 13psi when I install the DP and MP / Apexi exhaust. Recently the 7 smokes at startup and has boost problems, 9 psi. I believe the secondary turbos has an external leak and is dripping on the DP because you can smell burning oil, also when getting an oil change I got a chance to glance underneath it, oil was spread all underneath the body. You guys think it's the turbos? I know I need a new ECU and the PFC is in mind but waiting to install the new turbos first.
Thanx
Old Jul 1, 2002 | 06:19 PM
legendr35's Avatar
sounds like the turbos to me..
Old Jul 1, 2002 | 09:04 PM
dasalnt's Avatar
dont listen to this guy, he doesnt know anything bout rx7's. He raced a type r with 4 lbs of boost and it was on his *** the whole way. =]
Old Jul 2, 2002 | 05:05 PM
RavenRx7's Avatar
great --- well I will find out, I just didn't think the turbos would smell so bad. The smell is very strong!
Old Jul 2, 2002 | 08:08 PM
MazdaMike's Avatar
does it smell syrupy?
Old Jul 3, 2002 | 12:59 AM
rrrmechanic's Avatar
might be your oilmetering lines . check for oil on engine block right behind second turbo if driping wet that might be it
Old Jul 3, 2002 | 04:29 PM
JONSKI's Avatar
5yr member, joined 2001
It's your turbos. Mine does the same thing. Smoke on start up and smoke at WOT. I took off my primary turbo inlet a few days ago to block off my EGR valve, and oil dripped out when I took it off. My oil gaskets are going.
Old Jul 25, 2002 | 11:03 PM
nrolfes1's Avatar
mine do it too. i've put 10K miles on my car in that condition and its still running so i don't think its a dire situation.
Old Jul 26, 2002 | 01:08 AM
ur turbo seals are goin bad.. smokes really bad?
Old Jul 26, 2002 | 06:19 PM
rotary-tt's Avatar
2 babies - no back seats
Rotaries smoke at startup without turbos. I had a 1st and 2nd gen both do this. And for the oil, check where it is coming from. If it is wet under the steering rack then your front cover seal is most likely gone. The oil return lines on the turbos can also leak.
13
Jan 9, 2018 11:19 AM
AXA
Sep 5, 2015 10:06 AM
