Compession : Smoke or Steam?
Old Jun 23, 2002 | 10:11 PM
I was in my 83 in a parking lot one day and when i pulled away i noticed all of my coolant was gone. Like and idiot i drove short distances back to my house. When i got there there was smoke coming out of the hood. My dad says it was just steam. What is it and what should i do. He says that i have a busted heator hose. Is the engine gone?
Thanks
Justin
Old Jun 23, 2002 | 10:20 PM
SilverRocket's Avatar
EliteHardcoreCannuckSquad
Find the leak and fix it; sounds like your dad has a head start.
Hopefully you didn't do any damage by possibly overheating. I wouldn't jump to any conclusions about your motor being "gone".
Old Jun 24, 2002 | 07:26 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
I agree about not jumping to any conclusions.
However, don't EVER do that again! It's just about the WORST thing you can do.
Old Jun 24, 2002 | 08:13 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Yeah after i lost a heater hose, and overheated my engine in my 80. It still ran fine, but leaked oil outta just about every orfice there was
Old Jun 24, 2002 | 03:11 PM
DO you thinki have low compression now and about how much would it cost to get it rebuilt
Old Jun 24, 2002 | 03:13 PM
We don't know if you have low compression, if you want to know that you have to check yourself. Again, you're jumping the gun. Fix your busted hose and then see what happens.
Old Jun 24, 2002 | 06:17 PM
Heres another one. I have an oil leak between rotor housings. It is right inder the oil filter and the the filter is not leaking so i think that is a broken gasket. I have heard that they sometimes come from the factory that way. Should i worry about that.
Old Jun 24, 2002 | 06:31 PM
There are 2 o-rings under the oil filter pedestal - it is common for them to leak, especially on cars like yours with the small oil coolers under the filter. You can pick up new o-rings at your local Mazda dealer for cheap. However, as I remember one of the bolts is pretty hard to remove, you might need some kind of a special tool.
The usual leak on the engine is the infamous dowel pin leak, which as I understand it manifests itself by a pool of oil near the "Mazda" writing on the top of the engine.
Old Jun 25, 2002 | 02:40 AM
Pedestrian X's Avatar
SpAz!
yea, its sorta ironic.
Old Jun 25, 2002 | 02:58 PM
Hahaha, good point.
ls1swap
Jun 3, 2024 03:25 PM
mulcryant
Oct 4, 2015 12:18 AM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
