MY DevilsOwn Pre Turbo water injection.
Old Apr 16, 2010 | 09:39 PM
silverfdturbo6port's Avatar
500+hp club
So after a long build i bit the bullet and bought a injection set up. I decided to do pre turbo injection as i wanted to expiriment with it a bit. I went with DevilsOwn Injection kit (stage 1) i did a D02 nozzle preturbo in my filter and i did a D10 at my throttle bodie elbow and i am running straight distilled water . I am running 23psi and will post some results later but here are some pics i thought i would share.
Old Apr 24, 2010 | 06:34 PM
devilsown's Avatar
Nice looking install. How well is it running?
also what did you use for a nozzle holder?
Old Apr 24, 2010 | 06:53 PM
SmogSUX's Avatar
No money. No love.
So you're running one pump to the TB and Filter?
Old Apr 26, 2010 | 02:39 PM
500+hp club
yes sir. i use a splitter
Old Apr 26, 2010 | 03:49 PM
StavFC's Avatar
Looks good man
Im running a Devils Own kit pre-compressor now too, working well so far, using the 10GPH jet activated at 9psi.
Only running 16psi so far as not hooked up the wide band to take a close look yet, but im hoping to safely hit about 23psi on pump fuel.
My pump is behind the passenger seat and the tank is just behind, a 6 litre alloy tank, which doesnt last long with a 10GPH jet, thats for sure!
Old Apr 26, 2010 | 07:30 PM
500+hp club
10gph pre turbo??? huh i was told to do a smaller jet pre turbo and a bigger after. but yea i turned my washer res into a tank since its already mounted and it actually lasts quite a while i thought it was going to go thru more. going to go dyno here soon as soon as i get my supra pump in.
Old Apr 28, 2010 | 01:23 AM
incubuseva's Avatar
Boost knob
Your engine bay = sex.
I'm getting my kit in the mail here pretty soon. Probably going to run a similar setup as yours as well. I'd love to see your dyno sheet.
Old May 11, 2010 | 05:29 AM
rotorooter93fd's Avatar
YOUR TRIANGLE NIGHTMARE
silver fd turbo 6 port what kind of numbers are you making?
+1 for an awesome looking engine bay keep up the good work!
Old May 19, 2010 | 10:49 PM
500+hp club
dont know yet. been way busy lately but i will got it dyno'd sooner or later
Old May 20, 2010 | 07:07 PM
SmogSUX's Avatar
No money. No love.
Just curious-what was the point in running water to both the TB AND the filter?
Old May 20, 2010 | 10:26 PM
500+hp club
do some research. maybe look at some howard coleman threads
Old May 21, 2010 | 06:02 PM
SmogSUX's Avatar
No money. No love.
I'll check into it...what I had noticed before was kind of a either one of the other attitude though.
Old May 21, 2010 | 09:49 PM
500+hp club
yea some do and some dont. i love water injection i do pulls after pulls and the intake temps stay rock solid
Old Jun 4, 2010 | 01:20 PM
AlexG13B's Avatar
brap brap brap
im runing similar setup on fc. but my stupid iat sensor on haltech doesnt seem to read the temp drops.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
sherff
Feb 24, 2019 12:09 PM
FD7KiD
Aug 17, 2015 11:50 PM
