Update on car rebuild
Old Mar 4, 2010 | 03:07 PM
IronMdnX's Avatar
Glutton for Punishment
I have not been on much lately. I have alot going on in my life. I have returned back from CA now after the job started then we had the contract fall through.
I have had some time to start working on the car and did some traveling.
Unfortunately I will be putting the car up for sale real soon.
Here are a few photos of my progress
Old Mar 4, 2010 | 03:09 PM
IronMdnX's Avatar
I did pull the car out of the garage today and snapped some more photos
Old Mar 4, 2010 | 03:12 PM
IronMdnX's Avatar
All that is left is to fix a few dents on the driver's side, minor body panel adjustment, final filler, block sanding and paint. I am not a painter and am not going to try.
It also need to have 1 rim fixed that was bent. Any recomendation sense The SSR GT3's are not made anymore?
I'll post a pic of it.
Old Mar 4, 2010 | 03:19 PM
IronMdnX's Avatar
I know they are a 3 piece rim. And the outer bent part is removable.
I've been keeping my eyes open on ebay for one that could be used.
Old Mar 5, 2010 | 12:29 AM
Valley3's Avatar
Chewing on Tarantula
Looking like you're back in the saddle again..
Old Mar 5, 2010 | 10:14 AM
RX-Heven's Avatar
I'll blow it up real good
CCW's for the win.
Nice job so far, glad to see it going back together.
Old Mar 5, 2010 | 12:52 PM
McCarthy's Avatar
Good job dude.
Old Mar 5, 2010 | 04:58 PM
Suicide Machine's Avatar
Born to lose..Live to win
glad to see its back together....or heading there
Old Mar 5, 2010 | 10:03 PM
Way to hang in there and bring the car back to life.... I say keep it
Old Mar 7, 2010 | 10:23 AM
Japan2LA's Avatar
Plus one...What he said ^....
Old May 8, 2010 | 08:03 PM
IronMdnX's Avatar
An long due update.
The past week or two I've been prepping the car for paint. I am going to do a full color change, and add rear flares from shine auto. I wanted to do more of the body kit, but money is limited at the moment. I'll add the other pieces when I am able. I also had a '99 spoiler I can finally put on after sitting in the attic for 4 years.
I just want to get the car out.
Here are some pics after 1st round of block sanding and recoat .
I'll start the final sanding after the flares arrive tuesday.
Here is the color I am going with. It is the 2010 40th Anniversary Eddition 370z Graphite Metallic.
The PPG supplier had to order some of the components to make the paint. It will be ready tuesday.
Old May 8, 2010 | 08:11 PM
OneRotor's Avatar
RAWR
It'll be epic when you get done. Car is coming together nicely. Are you going with the JimLab 8.8" Cobra IRS conversion?
Old May 8, 2010 | 08:23 PM
IronMdnX's Avatar
It is on the list to do.
I have most of the parts, just need the subframe, axle shafts, and driveshaft. I may try it with the 3.55 gears, I'm sure i'll end up changing them.
Old May 9, 2010 | 01:33 AM
Ottoman's Avatar
always modding
Can u paint the front window area properly without removing the glass?
Old May 9, 2010 | 01:37 AM
scrapp's Avatar
89GTUs (38k original mi)
I want to see the progress. Keep the car!
Old May 9, 2010 | 07:01 AM
IronMdnX's Avatar
Using tape to pull back the rubber seal so it can be painted underneath. Originally I was going to R&R the windshield, until I heard about the trick.
Old May 19, 2010 | 08:22 AM
in5an3's Avatar
keep up the good work champ.
Old May 19, 2010 | 10:45 PM
IronMdnX's Avatar
Car was painted last weekend. Starting to reassemble and color sand it. This week has been busy. I should have it together this weekend. Then I just need to have an alignment done and a DOT signoff.
Old May 19, 2010 | 10:51 PM
Japan2LA's Avatar
Looking good!!!
Old May 20, 2010 | 10:08 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
you are one lucky guy consider what happened on the road.
i really like your color choice it goes w all the breakthru engineering you did on your car.
i am waiting on my machine shop to verify CL on my adapter plate and drill four holes for the hydraulic clutch release bearing. in theory end of next week. it is then a bolt together.
good luck and i hope things work out that you are able to keep your magnificent FD.
howard
Old May 25, 2010 | 06:43 PM
Japan2LA's Avatar
More pics more pics more pics
Old May 25, 2010 | 08:04 PM
Tj Hunter's Avatar
You are close to me, I hope I get a chance to see that some day! Looks good, what happened to the car, or did you buy it that way?
Old May 26, 2010 | 10:31 AM
IronMdnX's Avatar
I wrecked the car last fall.
https://www.rx7club.com/20b-forum-95/not-good-day-wrecked-car-869164/
Old May 26, 2010 | 10:33 AM
IronMdnX's Avatar
Here are some updated pics.
Still working on color sanding and then the final buff.
I'm still looking at options for rims. I added the burnout rear flares to allow a wider tire. I should be able to fit 335's on there, if not I'll go with 315's.
Old May 26, 2010 | 10:38 AM
scrapp's Avatar
Nice, looks good, you happy with it?
