turbo question..
Old Feb 24, 2010 | 10:51 PM
thejallenator's Avatar
turbo question..
ok after lookin at pictures i think that my turbo is missing a few pieces. can any one confirm this? just starting in the turbo world so im still curious.
Attached Thumbnails turbo question..-dsci0383.jpg   turbo question..-dsci0384.jpg   turbo question..-dsci0385.jpg   turbo question..-dsci0386.jpg
Old Feb 25, 2010 | 12:52 AM
rotary-guy's Avatar
2jz'd fc
oil feed/drain, water feed/drain lines, wastegate, and backing plates to hold your compresser housing on
Old Feb 25, 2010 | 10:30 AM
rotorette's Avatar
That Chick
The compressor "cold side" backing plate is there, its under the comp wheel, but you are also missing the exhaust/down pipe plate on the back of the turbine.
Old Feb 25, 2010 | 03:23 PM
so the oil/water feed and drain, waste gate and teh plate on the back for the dp? also it doesnt appear to have the backing plate to hold the compressor housing on. where do i go about finding these missing pieces also?
Old Feb 25, 2010 | 08:52 PM
rotary-guy's Avatar
2jz'd fc
ment the pices that hold the housing on, there is 3 i believe, you know the pices that join 2 bolts and span a little across the plate
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
FD7KiD
Aug 17, 2015 11:50 PM
