Megasquirt MSI 2.2 runing spark
Old Jan 27, 2010 | 05:07 PM
rolfs_7's Avatar
i play with my wankel
Ok so I've got an MSI 2.2 (green pcb) and I want to run spark now. So from what I've gathered with the MS1 board I need the Zeal board, wired like the pic below, and the pull up resistors installed at the LEDs. Then obviously changes in Map for ignition. Just making sure thx guys
Old Jan 28, 2010 | 09:03 AM
Aaron Cake's Avatar
Engine, Not Motor
Basically. You can use the Zeal card, or make a dual LM1815 circuit on another board. The Zeal is easiest and also comes with a few other features.
Like other boards, the 2.2 needs pullup resistors on the LEDs.
Old Jan 28, 2010 | 05:41 PM
rolfs_7's Avatar
As always thanks a ton Aaron, I just want to clarify before I jump into this. The pullup resistors on the LEDs need a 5v supply right?
Old Jan 28, 2010 | 05:58 PM
elturbonitroso's Avatar
yes
Old Jan 28, 2010 | 06:18 PM
rolfs_7's Avatar
Anywhere easy i can pull this off the board?
Old Jan 29, 2010 | 03:21 PM
Aaron Cake's Avatar
Engine, Not Motor
Just follow the instructions in the FAQ for adding the resitors. These are valid for both 2.2 and 3.0.
Old Jan 29, 2010 | 11:48 PM
rolfs_7's Avatar
Thx Aaron. I apologize for overlooking that and I kinda feel like a buffoon!
Prediict
32
Nov 18, 2015 08:41 AM
Aramir
Oct 18, 2015 02:39 AM
tctwaites
Sep 22, 2015 08:48 PM
