TID mod and homemade bov
Old Jun 15, 2002 | 10:04 AM
Ryde _Or_Die's Avatar
Alright well I did search so don't try that "try the search" stuff I didn't find what I am looking for though. Alright I want to do the TID mod. I read a write-up that said I need a 3" 45* piece of PVC, a 3"-2.5" silcone reducer, a 3" silcone hose, and various hose clamps. What else would I need? I know I need some sort of check valve, what for and what size? Is there a site with some good pics so I know exactly what to do? What about the stock BOV? I would like to make a homemade BOV while I am at it, so what else would I need to do that? Thanks alot for any input.
Old Jun 15, 2002 | 10:29 AM
CanadianRX7's Avatar
I would love to hear the answer to this...i wanna do the same thing...u need 2 vacuum nipples....one for the stock blow off vavle and the other for the stock boost controller...thats on the 89-91 models....i think the 89-91 model only has one though..
"There are 2 things that plumb into the duct - the compressor bypass valve and the PCV breather tube"
"You'll need to figure out how to plumb in the emissions fittings (one for 1986-1988 models, and two for 1989-1991 models) and the stock compressor bypass valve (i.e. stock blow-off valve), if you're planning to keep them intact."
You probably have all the sites but here are the ones i have found and the top 2 are the best with pics...
http://www.teamfc3s.org/info/articles/tild.html
http://www.1300cc.com/howto/how2/TID.htm
http://fc3s-pro.com/TECH/MODS/ENGINE/IN/tid.htm
here is a article on the do it yourself blow off valve http://www.teamfc3s.org/info/articles/blowoff.html
Old Jun 15, 2002 | 02:54 PM
fastrotaries's Avatar
W. TX chirpin Monkey
Try a search !!!!!! Sorry dude i just had to. I've heard the same though. Sounds like a good idea.
Old Jun 16, 2002 | 06:08 AM
NZConvertible's Avatar
I'm a boost creep...
Re: TID mod and homemade bov
Um, why? That's a pretty serious undertaking. You'd need to machine all the components up from aluminium using a milling machine and a lathe. Quite precise engineering is required to make one work properly and not leak. A guy I know made his own, but he's a machinist by trade, and said it was alot of work for a one-off.
Old Jun 16, 2002 | 06:39 AM
dvls-7's Avatar
Sick & Twisted
Thanx guys, I was gettin ready to do the same thing, save me havin to search.....now i got something to do this weekend, hope the weather clears up
Old Jun 16, 2002 | 06:52 AM
peejay's Avatar
Old [Sch|F]ool
Re: Re: TID mod and homemade bov
I was thinking of doing it but using a cut-up old cylinder head for the valve and seat, or maybe a butterly valve, which would be easier to actuate because you can make the diaphragm external, similar to how factory wastegates work.
Yes it's a lot of work to save $200
edit: Actually the cylinder head idea would be sweet for an external wastegate, come to think of it Heck you could even make the wastegate water cooled!
Old Jun 16, 2002 | 10:18 AM
Aaron Cake's Avatar
Engine, Not Motor
If you look at my turbo status #4, you will see my TID...It's basiclly self explanitory, though I don't know if it will fit a stock TII.
Old Aug 31, 2004 | 06:13 PM
jasonw3579's Avatar
i don't think he meant creating an actual BOV.... just open venting the stock one to get the WHOOSH sound
demetlaw
Oct 2, 2015 06:22 PM
musker
Oct 1, 2015 05:58 PM
