Na T noob question.
Old Jan 9, 2010 | 04:42 AM
Linguo415's Avatar
Na T noob question.
I just read an awesome thread on putting a turbo on an na engine. It sounds like something I might cosider doing to my 90GXL. It sounds like it's ok to do at low psi. But how safe is it to upgrade other things like the exhaust or the intake and innercooler after having put on the turbo? Won't upgrading these thing create greater boost presure inside the engine?
Old Jan 9, 2010 | 10:41 AM
Aaron Cake's Avatar
Engine, Not Motor
It is my opinion that turbocharging the NA to run low boost isn't worth the hassle. It depends on what you consider to be low boost and from what turbo though. As an example, I think it is crazy to bolt on the stock turbo and run 5 PSI.
A turbocharged NA will have the same upgrade path as a factory turbo car. Start upgrading the exhaust and other components and you will have to address the fuel system. Boost will most likely be raised and thus the car will require more fuel.
Old Jan 10, 2010 | 08:53 PM
funkjaw's Avatar
If you use an S4 or S5 turbo you will have problems with boost creep (S4) and minor boost creep (S5) after putting on a larger exhaust.
Old Jan 11, 2010 | 04:25 PM
Linguo415's Avatar
I see. I thought that was most likely the case after trying to upgrade anything. Too me it sounds like it is more cost effective to boost the the na i already have rather than buying a t2 engine and tranny and have to rebuild. It just dosent sound like it is safe to increase the boost because of the na higher compression ratios. Maybe I'll end up just going with the t2 engine in the end though. I always wanted a true s5 t2. Ha.
Old Jan 11, 2010 | 04:34 PM
Linguo415's Avatar
Na T noob question
[QUOTE=funkjaw;9728821]If you use an S4 or S5 turbo you will have problems with boost creep (S4) and minor boost creep (S5) after putting on a larger exhaust.[/QUO
What exactly is boost creep. Is that the same as turbo lag?
Old Jan 11, 2010 | 04:57 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Boost creep is the wastegate being overwhelmed to the point that the turbo just keeps building boost unchecked.
Old Jan 11, 2010 | 05:23 PM
soulrider's Avatar
http://www.allpar.com/mopar/boost-creep.html
should clear up boost creep and spiking
Old Jan 12, 2010 | 09:22 AM
Aaron Cake's Avatar
Engine, Not Motor
If you have to ask these questions, don't attempt an NA-turbo setup.
Old Jan 12, 2010 | 03:09 PM
Linguo415's Avatar
Point well taken Aaron cake. Haha. That's why I'm on this forum. To learn all I can about my car.
Old Jan 12, 2010 | 03:57 PM
Linguo415's Avatar
Na t noob question
Thanks for the info. Very good to know. So how can boost creep and spike be prevented? Won't a blow off valve upgrade help to regulate boost levels?
Old Jan 12, 2010 | 05:20 PM
RTRx7's Avatar
Rammer Jammer
Did you not read what he said about the wastegate?
Old Jan 12, 2010 | 09:54 PM
funkjaw's Avatar
You have to port the waste gate if you use an S4 or S5 turbo and waste gate to prevent boost creep.
http://fc3spro.com/TECH/HOWTO/howto.html
Has some good info.
Old Jan 13, 2010 | 02:14 PM
Linguo415's Avatar
Oh word. I must have skipped that part some how. So milling out the waste gate will take care of the boost creep issue. That makes sence.
Old Jan 13, 2010 | 02:24 PM
Linguo415's Avatar
So what turbo would be best to boost the na with? S4 s5 or after market?
Old Jan 13, 2010 | 03:34 PM
Aaron Cake's Avatar
Engine, Not Motor
How much power do you want to make? And how much money do you have to spend?
Old Jan 13, 2010 | 08:24 PM
sctRota's Avatar
BRAP PSHHH
ON
True plus u cant just put in a turbo, u need to also balance it off with other upgrades
Old Jan 15, 2010 | 01:19 PM
Linguo415's Avatar
Well it looks like I won't have a car anymore anyway. Some dumb chik smashed my door with her suburban. Her insurance is totaling the car. Lame!
Old Jan 16, 2010 | 10:35 AM
Aaron Cake's Avatar
Engine, Not Motor
I don't understand how her insurance can decide what to do with your car? Unless insurance operates in a backwards and ridiculous way in the USA? Should not your insurance be making that decision? And if you can supply them with receipts which prove the value of your car, it probably won't be totalled unless the damage is catastrophic.
Old Jan 16, 2010 | 12:20 PM
bostonspgs's Avatar
Boston Acoustics SPG555's
Actually the other cars insurance is the one that has to pay out first if he has liabilty coverage. if you have full coverage the other company still comes first and if you arent satisfied you can go to your insurance. Unfortunately stock FCs arent worth much to the insurance companies, ie i got 4600 for my s4 na (which they told me was a turbocharged inter cooled 2 cylinder. i had 3gs in rubber and rims on the car and they wouldnt pay for them properly , they offered me 300 dollars for them.
Old Jan 16, 2010 | 12:27 PM
RTRx7's Avatar
Rammer Jammer
You can insure a car for whatever you want. You will just fork over bigger payments. Liability coverage is only to keep you legal so that if you hit someone else, your insurance will pay for the damage and the person won't sue you. Full coverage will cover the damage no matter the cause but you will pay double if not triple in some cases what you would for liability insurance. Also, they don't have to total your car. Total just means that's how much they will give you for the whole car if the damage is like a half or a third of what the whole car is worth. If you like they will cut you a check for a portion of the damage and you can use that to fix it. I guess the op didn't know that like a lot of people in this country.
Old Jan 18, 2010 | 12:02 PM
Linguo415's Avatar
Ya well either way my fc is about go away in a week. Sucks I've only had it for a total of a month. It got hit the first week I got it. Dumb chik. She said she didn't see it. The car is blaze red. She said my car is too low. What a rediculous excuse. Wow
whinin
Mar 30, 2019 07:53 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
RXeckless
Sep 12, 2015 04:52 AM
