S5 NA Emissions Removal Hose Diagram
Old Nov 19, 2009 | 11:34 AM
Gringo Grande's Avatar
1.5 Goodfella's Tall
I have these for the S4 NA and Turbo and a S5 Turbo. At one time a member had made a very nice version of this for the S5 NA. Anyone still have this?
Search is down so can't find it. =(
Old Nov 19, 2009 | 12:49 PM
rx7nubie's Avatar
sry im not answering your question but is there a way you could send me the one for the s4 na? i would really appreciate it
Old Nov 19, 2009 | 11:56 PM
PM me with your email address.
Old Nov 20, 2009 | 07:47 PM
walken's Avatar
Registered Loser
this is a bad idea
having that many posts you should know your way around an intake manifold.
everything gets blocked off (save for BAC) and capped off, except for the fuel pressure regulator line and pressure sensor. make sure to reattach the line for the oil injectors. gonna mod the TB too? might as well swap on s4 manifolds, because it's going to drive like ****. pl
Old Nov 20, 2009 | 10:07 PM
shampoop's Avatar
Black 91 gxl
exactly how would it make the car "drive like ****" if you remove everything except the air control valve and the air pump?
Old Nov 21, 2009 | 12:04 PM
walken's Avatar
Registered Loser
unplug your vdi and take the car for a ride.
Old Nov 21, 2009 | 07:31 PM
shampoop's Avatar
Black 91 gxl
what does removing emissions components have to do with removing your vdi?
Old Nov 22, 2009 | 06:07 PM
walken's Avatar
Registered Loser
you need all that crap for a s5 n/a to run properly. you can rig it, but the ECU does it better.
24seven_dada
20
Nov 10, 2018 12:03 PM
ZacMan
Sep 19, 2015 09:20 PM
NotMrButts
23
Sep 15, 2015 09:46 PM
risingsunroof82
Sep 7, 2015 01:11 PM
