Drifting Discuss Drifting and drifting techniques here.
Heavy or light flywheel for drifting? Whats you opinion?
Old Aug 10, 2009 | 05:48 AM
julzrx808's Avatar
Just wondering what peoples thoughts are on flywheel weight. I currently run a ten pound flywheel on my 13bt but am considering going heavyer for more throttle control and slower rising revs. When the car is in a skid it's hard to keep it away from the rev limiter
What do other drifters recommend??
Old Aug 10, 2009 | 03:56 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
Better throttle control or shift up?
Old Aug 10, 2009 | 05:46 PM
Zerkster's Avatar
RTRY-FTW
i like my lightweight, heavy makes it feel like a fat bitch
Old Aug 10, 2009 | 06:19 PM
JebusFC's Avatar
Why you trying to keep it away from the rev limiter? I like lighter, if its lighter its more responsive to your inputs and also its easier to get the revs back up if it startes to bog down.
Old Aug 10, 2009 | 09:12 PM
nightridaz777's Avatar
Welded Ass Hell
stock flywheel seems to work best for me. im n/a so i dont know if that helps at all.
Old Aug 10, 2009 | 10:56 PM
Zerkster's Avatar
RTRY-FTW
weird thing is.... im running stock S4 ECU from an 87TII N332... I have no rev limit or fuel cut?
ECU was never opened or tampered with
Old Aug 11, 2009 | 01:12 AM
Andor's Avatar
if you clutch kick much you dont want to go too light because you need the inertia of a heavier flywheel for clutch kicking to be effective.
Old Aug 11, 2009 | 01:35 AM
K!NCH's Avatar
I dont have a rev limiter on mine na S4
Old Aug 11, 2009 | 02:41 AM
julzrx808's Avatar
Cheers for the input all.. It feels like i could prob do with a bit more inertia. I'm just looking to hold the revs more easily in the drift between 5 and 8 grand.
Old Aug 11, 2009 | 07:32 AM
Welded Ass Hell
+1
Old Aug 11, 2009 | 09:27 AM
Ranzo's Avatar
never had a problem with clutch kicking a light flywheel but to each his own i guess.
heavy takes from response and the power going to the ground dont see any advantage to having more inertia in drifting
Old Aug 13, 2009 | 01:50 AM
NoPistons!'s Avatar
Tango Down
Same.
"what's your redline?"
"it just keeps going!"
Old Aug 13, 2009 | 02:41 AM
Zerkster's Avatar
RTRY-FTW
http://www.youtube.com/watch?v=mn-KGB3pVsM
My diff blows at 1:20 ... laps were ok, nothing special didnt have the coils dialed in yet.
WARNING: chick videoing is a ******* SPED... youll see what I mean
EDIT: when my diff blows listen to the revvs
Old Aug 13, 2009 | 03:05 AM
Derek King's Avatar
might be sped but she deff new right away that you broke
Old Aug 16, 2009 | 12:02 AM
lonetlan's Avatar
Too Many Questions
Does power effect the decision of getting a lighter flywheel or keeping a heavier one?
Old Aug 16, 2009 | 03:10 AM
Zerkster's Avatar
RTRY-FTW
King im not following you? I had a bad clutch and she probably thought thats what broke
Old Aug 16, 2009 | 04:20 AM
Welded Ass Hell
he's just saying that she knew something broke when it happened by her comment.
Old Aug 16, 2009 | 05:02 AM
Zerkster's Avatar
RTRY-FTW
if she didnt know from that, she deff knew when 10 people had to push it up the bank lol
Old Sep 5, 2009 | 05:47 PM
NoPistons!'s Avatar
Tango Down
It's all preference.
After you drive for a while, you'll figure out just what you need. You can feel it.
That's why when i first got my rx7 everyone told me to leave it alone and drive it, ALOT and then figure out how i should go about modding.
Old Sep 5, 2009 | 09:11 PM
lonetlan's Avatar
Too Many Questions
Thanks nopiston for answering that question.
Old Sep 6, 2009 | 04:37 AM
Zenki FC3S's Avatar
\\TRASHTALK//
yea im running a stock flywheel and like 240 hp and it feels good but my bro has a 3 puck clutch and a 11lb flywheel and that **** is tooo ******* sick. Turn 4 at firebird main is can be linked differently when i drive his car. that **** is at like 375 horses but still it breaks with ease when i just front brake and press the clutch simultaneously then floor it pre apex of the turn. wish i had vid of that turn but yea i love the three puck and lightweight they seem to go hand in hand. havent done much clutch kicks with his set up cuz outta respect and also the power and welded diff breaks it loose too easy, but i heard of the aluminum flywheel heating up with mad cluth kicks sessions maybe it could **** up or warp due to heat...
Old Sep 6, 2009 | 11:45 AM
It causes hot spots on the friction surface.
whizzybang
Naturally Aspirated Performance Forum
21
Feb 10, 2017 12:08 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
