Bleed Screw Broke!
Old Aug 3, 2009 | 04:41 PM
Bluewind's Avatar
Question Bleed Screw Broke!
Help!
The previous owner of my car installed a Stoptech brake kit. Somehow he overtorqued and jammed the bleed screw so that when I tried to open it, it snapped in half... Currently where the bleed screw was is now a broken piece of metal level to that of the caliper. I have no way of opening/closing or removing the screw. All i see is a small hole where the fluid was supposed to come out of.
How can this be repaired? Stoptech said they cannot help me.
Old Aug 3, 2009 | 05:25 PM
Mahjik's Avatar
Mr. Links
Remove the caliper and see if you can use an ez-out.
Old Aug 3, 2009 | 09:12 PM
HotRodMex's Avatar
I found a tip online: Find a square or hex bit to hammer into the bleeder bolt hole. you should be able to turn the bolt out after a few good whacks.
Old Aug 5, 2009 | 04:32 PM
Bluewind's Avatar
Angry
This didn't work!!!
The bit snapped in half with it stuck in the center of the bleeder hole. Now this is going to make drilling very difficult.
Old Aug 5, 2009 | 11:21 PM
HotRodMex's Avatar
Originally Posted by Bluewind
This didn't work!!!
Your **** must be way frozen then. I even used a cheap Chinese bit and didn't have that problem. Mine actually broke up the bleeder a bit and I had to re-hammer it.
That is some real shitty luck.
Old Aug 6, 2009 | 01:52 AM
Bluewind's Avatar
I was researching this problem a bit and I've seen quite a few threads where backouts actually break. I'm going to have a friend drill it out and use a Wilwood Bleeder Repair Kit. It basically acts as an adapter where you drill and tap the old broken off bleeder. Hope this works, I'm not looking forward to buying a replacement Stoptech caliper.
Old Aug 6, 2009 | 11:30 AM
burtoncr's Avatar
I would think Stoptech could sell you the bare caliper half.
Old Aug 6, 2009 | 03:00 PM
Bluewind's Avatar
If they sell just the half, that would be great.
I'm wondering if I should drill and tap the passage/body of the caliper for a new bleed port.
Old Aug 6, 2009 | 07:44 PM
HotRodMex's Avatar
That would be a question for StopTech.
Old Aug 10, 2009 | 11:43 AM
Bluewind's Avatar
Problem Solved: Friend had a set of Tungsten Carbide tipped drills, which is designed for drilling through hardened steel. The rest came out with an ez-out. ~whew
ls1swap
Jun 3, 2024 03:25 PM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Sethix
Nov 3, 2017 11:48 PM
Andrew7dg
Aug 6, 2017 01:41 PM
wthx100
11
Oct 1, 2015 10:23 PM
