Sponsored by: CARiD
Trans/Mods for 400rwhp
Old Jun 28, 2009 | 07:26 AM
zaridar's Avatar
35r 13b first gen
Question Trans/Mods for 400rwhp
I'm building a first gen 12a turbo car and will be right around 400rwhp... Does anyone have suggestions for which tranny to use and or what mods i can make to my 12a gsl tranny? Will a TII tranny hold up? if so will it bolt up to a 12a and will i need to get a new clutch? i have a new centerforce dual friction now for the 12a tranny....
Thanks
Josh
Old Jun 30, 2009 | 06:19 PM
farberio's Avatar
NASA-MW ST4
You should be able to run the TII trans. You may have to fab up a mount and a driveshaft though. There is forum post that goes over all of this if you search for it.
It will bolt up to the 12a as far as I know, you will have to run a turbo flywheel, clutch, and hydraulics.
Old Jun 30, 2009 | 07:37 PM
silverfdturbo6port's Avatar
500+hp club
here is a fun easy solution that i have used. make sure you just buy tires that will lose traction under a lot of load i would rather buy cheap tires than clutched and transmissions but just a idea
Old Jun 30, 2009 | 08:21 PM
cptpain's Avatar
Torqueless Wonder
Make sure you have a plan of attack on the differential.....
the rear ends are the weak link.
use the GSL-SE rear end, stronger axles, and a miata LSD and the only thing you'll have to worry about is how to dial in the suspension.
Old Jul 2, 2009 | 03:20 PM
zaridar's Avatar
35r 13b first gen
How does the GSL limited slip hold up? Im getting moser axles from billy sometime in the future along with the big brake kit and rack and k member conversion. Are the ring and or pinion the weak link or primarily the axles? Thanks guys
Old Jul 8, 2009 | 01:44 PM
zaridar's Avatar
35r 13b first gen
bump
Old Jul 11, 2009 | 09:33 AM
CoffinRX2's Avatar
I'm currently running a Series 2 with a 12abpt motor that was previously putting out 300rwhp. Currently getting rebuilt for more power.
I'm currently running a series 3 rear end and LSD, Series 4 turbo gearbox. I've been told that I'm going to have to upgrade the rear end, and will be going to a shortened Toyota hilux conversion
Old Jul 11, 2009 | 01:26 PM
zaridar's Avatar
35r 13b first gen
Besides what people have told you how is what you are running holding up? Have any problems yet?
Old Jul 12, 2009 | 03:40 AM
CoffinRX2's Avatar
Well at the moment I'm running minimal rubber, 205's on the back and are just crap street rubber nothing too sticky.
I'm happy having that as my "achilles heel" as the wheels just spin and take a lot of stress from the driveline.
J_Painter87
15
Jul 9, 2005 05:08 PM
Net Seven
Mar 31, 2005 07:50 PM
MazdaRx7Racer4Life
125
Feb 28, 2005 04:55 AM
99E36M3
Jun 9, 2004 07:25 PM
MazdaRx7Racer4Life
Jun 1, 2004 02:53 PM
