My Tempeture gauge is not reading anything
Old May 30, 2002 | 08:16 PM
Question My Tempeture gauge is not reading anything
I recently installed a street porrted motor into my 1990 GTU. Before I took my other motor out the Tempeture gauge was working fine. Now it does not read anything at all. When the car is on the, I see if the wire has electricity and it does. Im pretty sure that it is the tempeture sending unit that screws into the motor but I want to make sure first. Does anyone know if this is the problem? Thanks, Nelson
Old May 30, 2002 | 08:24 PM
NZConvertible's Avatar
I'm a boost creep...
Are you checking the sensor under the oil filter? That's the guage one.
Old May 30, 2002 | 08:46 PM
telus.net's Avatar
take out that sensor and clean it. Check it again.
That always do the trick!
Old May 30, 2002 | 11:28 PM
Thanks for the reply telus.net. Im going to try that tonight to see if it works.
Old May 31, 2002 | 12:22 PM
Any body else know what can be wrong? Thanks
Old May 31, 2002 | 12:50 PM
silverrotor's Avatar
I agree with NZCONVERTIBLE. The Coolant Sender Unit or the wire leading to It would be suspectible.
Check to see If the wire Is on snug.
I replaced all my coolant sensors as cheap(?) assurance.
- Water Temperture Switch
- Water Thermo Sensor
- Coolant Level Sensor
- Coolant Sender Unit
Snoopy FD
Dec 8, 2015 01:45 PM
Thor 18
Interior / Exterior / Audio
Sep 13, 2015 08:39 PM
yetter227
20
Sep 5, 2015 11:57 PM
josef 91 vert
Aug 29, 2015 12:22 AM
