Quick Profec B wiring question
Old May 30, 2002 | 08:15 PM
silver93's Avatar
The wiring to the stepper motor - there is a green and a white wire. Which is positive which is negative?
I've lost my instruction sheet!
thanks!
Old May 30, 2002 | 08:22 PM
seabass's Avatar
the green and white wires goto the control box.
the red and black wires from control box goto power.
Old May 30, 2002 | 08:24 PM
GsrSol's Avatar
Z06 powered FD
The stepper motor has a plug that connects to the back of the Profec to green and white wires. Then another set of wires come from the Profec which are red and black, those are for power.
Old May 30, 2002 | 09:13 PM
silver93's Avatar
thanks, but here is my deal -
i never had the fancy male/female connector that goes to the stepper motor. I had to splice the + and - to the stepper wires. Anyway, I had to take the wires apart, and in my damn haste, forgot to mark them. Soooo...
is the white wire + or - ??
Thanks!
Old May 30, 2002 | 09:33 PM
Toadman's Avatar
Nomad Mod
Hope THIS helps. but don't tap into the pre-control actuator AND wastegate lines, just the wastegate one(with the pill)
Old May 30, 2002 | 11:52 PM
dlee's Avatar
If I recall, you can get the schematics from Greddy.com they have all the instructions there with color codes.
Just a thought.
Old May 31, 2002 | 06:12 AM
silver93's Avatar
yeah, tried greddy.com but no luck with the wiring diagrams -
Old May 31, 2002 | 11:03 AM
GsrSol's Avatar
Z06 powered FD
http://www.greddy.com/technical/pdf/ProfecB.pdf
So you don't know which one is white or green?
There are 4 wires coming out of the Profec, red, black, green, and white.
There are 2 wires coming out of the stepper motor, green and white. Those connect to the Profec and the Profec supplys the power when needed.
Old May 31, 2002 | 11:28 AM
silver93's Avatar
Yeah, I know there is the white and green wire coming out of the stepper motor. I need to know of those 2 wires (the white and green) - which is positive and which is negative -
I tried calling Greddy in California - those guys are F*****g idiots!
The guy was like "How are we supposed to know?" "Did you read the book, it says made in Japan" - amazing!
Old May 31, 2002 | 12:32 PM
GsrSol's Avatar
Z06 powered FD
I don't think we are understanding each other. I'm trying to say it doesn't matter as long as you hook up green to green and white to white. Now what I don't understand is your reasoning that you can't do that, which wires are stripped? Can you not tell which one is green or white?
I don't know which one is positive of those two but you can hook up the power to the Profec and use a test light on the green and white wires coming out of it.
Old May 31, 2002 | 12:43 PM
silver93's Avatar
you're right - i should go work for greddy cause now i feel like an idiot!
i didn't read your response carefully enough. my profec sits in the bin under the stereo, and so the colored wires from the profec are behind, so i never saw it, nor thought about pulling it out and looking. sooo..
thanks for the answer!
my bad !
Snoopy FD
Dec 8, 2015 01:45 PM
The Shaolin
Sep 14, 2015 07:50 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
