Exhaust head gasket?
Old May 25, 2009 | 01:16 AM
Jwilke's Avatar
Exclamation Exhaust head gasket?
So I recently bought a rx7 gx and when I bought it the guy told me that the exhaust header or something like that was leaking and would have to be fixed. Lately my car has gotten much louder and I believe that the would be from the seal getting worse or am I completly wrong any input on this would be helpful because i'm not to familiar with rotarys
Old May 25, 2009 | 08:28 AM
IanS's Avatar
Ricer
I suggest you climb under the car and check for holes in your exhaust first. It seems that once a small hole is formed, it gets larger pretty fast. Might be a fairly simple fix. If you cant find any leaks, it could be the exhaust manifold (header) gasket - the one that goes between the manifold and engine block.
Old May 25, 2009 | 11:08 AM
Dedlyvirus's Avatar
is it a stock exhaust? i just replaced my exhaust because the whole thing was rusted out. so it is possible that some parts are bad and forming holes.
Old May 26, 2009 | 12:40 AM
Jwilke's Avatar
It has an aftermarket racingbeat dual exhaust that looks like it's fairly new from what I can see so I guess it must be the exhaust manifold gasket. Does anyone know how much this is going to cost to get fixed? Or if it's easy enough to do it yourself where I would be able to fnd step by step instructions?
Old May 26, 2009 | 01:07 AM
thejallenator's Avatar
well not to sound mean but if your a complete idiot when it comes to using tools might as well shut up and take it to the shop. if not its as easy as takin offf the exhaust mani and pullin whats legt of the old on off then replace it and bolt it back together. couple hours max. easy fix tho
Old May 26, 2009 | 05:37 PM
Jwilke's Avatar
It's not that I'm bad with tools but I don't have much experience working on cars
Old May 26, 2009 | 06:53 PM
oh well its not much to taking off an exhaust manifold. i think the only think you may run into problem wise is just taking it off to get to the gasket. its nothing to major. kinda self explanitory. just go at it. you cfant really mess it up that bad
Old May 27, 2009 | 01:25 AM
Jwilke's Avatar
Ok well I guess I'll try that. Will it matter that I don't have a car jack? Any thing else I should know before trying this myself?
Old May 27, 2009 | 11:25 AM
that might make things hard to do. since i dont think you can reach the manifold bolts with the car setting on the ground. but im not sure.. you may be bale to get away with that.
Old May 27, 2009 | 12:36 PM
lwrider59's Avatar
RX7 Dude
I recommend buying or renting a car jack because its almost impossible to squeeze under the car and actually work under there without it being raised
Old May 27, 2009 | 01:26 PM
pmrobert's Avatar
A 1 or 2 day soak of penetrating oil may not be a bad idea. Those exhaust studs are extremely difficult to get out of you break one off removing the nuts which are often very frozen. If you're not familiar with car work, you may not want to start with this job. It's simple IF there are no complications.
Old May 28, 2009 | 01:16 AM
Jwilke's Avatar
Well since it would be a first and since I want to get my car a 60k mile tune I might just get them to do the gasket aswell anybody know how much both of those Are expected to cost?dont want to get ripped off or anything
Wicked93gs
44
Jan 12, 2022 10:08 AM
FD7KiD
15
Feb 26, 2021 10:12 PM
Kyo
Apr 13, 2019 09:24 AM
Azevedo
26
Mar 1, 2019 09:19 PM
FD7KiD
Aug 17, 2015 11:50 PM
