how much boost?
Old Apr 5, 2009 | 01:23 AM
solpower's Avatar
how much boost?
can a stock tII hold reliably?
Old Apr 5, 2009 | 10:19 AM
Aaron Cake's Avatar
Engine, Not Motor
Stock boost.
More with fuel mods.
Around 8 PSI with an FCD and no other mod. Any more requires an upgraded fuel pump. Around 10 PSI you need larger secondaries and some way to control them.
But the only way to be absolutely sure is to check AFR ratios. Some cars end up leaning out well before 10 PSI. Some are rich all the way to 12.
Old Apr 5, 2009 | 10:21 AM
supra an seven guy's Avatar
secondaries? there are more than two injectors? (im new to the rotary game alltogether sorry)
Old Apr 5, 2009 | 11:15 AM
RotaryRocket88's Avatar
Top Down, Boost Up
Yes. 2 primarys and 2 secondaries. The secondaries are staged to come on at 3800 rpm.
Old Apr 5, 2009 | 12:45 PM
solpower's Avatar
how do you build for big boost say 20 psi? im new to the rotary scene but knew it would need fuel mods.
Old Apr 5, 2009 | 07:09 PM
Top Down, Boost Up
On the stock turbo? You don't. It runs out of breath at about 12 psi, and will not last long when pushed over that mark constantly.
Old Apr 6, 2009 | 10:10 AM
Aaron Cake's Avatar
Engine, Not Motor
Don't even think of running the stock turbo at 20 PSI. At 13 PSI, it is dropping efficiency fast and is out of breath before 14 PSI. At that point is is pumping more heat then air and turbo life (as well as engine life) becomes questionable.
You will find the FSM in the FAQ sticky. It will familiarize you with the EFI system used on the RX-7.
Old Apr 6, 2009 | 07:43 PM
whiskey tango foxtrot's Avatar
i fought the lawn
+2, ....also, that would ring true with just about any small displacement turbo car. t3, 14b, vj12, any of em (i named a slight few of hundreds of different models of stockie snails) will turn into a hairdryer after about 1 bar.
Old Apr 6, 2009 | 08:41 PM
solpower's Avatar
lol sorry i know about the efficiency ranges for turbo thats not my question. my question is how do i build the actual engine for it. are their low compression rotors? if so where do i find them, better seals? etc
Old Apr 7, 2009 | 12:32 AM
Scrims's Avatar
Hide the pinball machine
it would be better to know your horsepower goals, not boost goals. Same boost will create different power with different turbos, and I think it's been established that you want more than the stock turbo can handle.
Old Apr 7, 2009 | 08:51 AM
Aaron Cake's Avatar
Engine, Not Motor
If you know about the efficiency ranges of turbos, instead of running an ungodly high number like 20 PSI, pick a turbo which is efficient at a lower boost for the power you want.
Telling us how much power you are looking for and the intended use for the car is a bit critical to receive good advice.
When you get into high boost levels like around 20 PSI, pump gas becomes a bit of a liability. Proper intercooling and some kind of chemical cooling (ie. meth injection) is necessary to maintain reliability.
Old Apr 7, 2009 | 04:49 PM
solpower's Avatar
im looking mostly to have a good 350 hp dd i have a supra for building for a monster i just want the rx7 to be a good bit quicker lol
Old Apr 7, 2009 | 06:07 PM
Aaron Cake's Avatar
Engine, Not Motor
GT35R at 15 PSI.
Old Apr 7, 2009 | 07:15 PM
solpower's Avatar
no internal mods needed?
Old Apr 9, 2009 | 09:32 AM
Aaron Cake's Avatar
Engine, Not Motor
Nope.
But you will need supporting mods like a full standalone, intercooler, fuel mods, etc.
Old Apr 9, 2009 | 01:21 PM
solpower's Avatar
thanks for the help!
will probably be starting this build over the summer lol
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
