help me please AVC-R related
Old May 26, 2002 | 05:47 PM
Dan's Avatar
Dan
I just instaled it, and now the car idles a little rough and the check engine light comes on. when its idleing and I hit the gas, it almost stalls out.
Old May 26, 2002 | 05:55 PM
93FD3S's Avatar
Big Snail
recheck your lines..
Hey bro check your lines again ....and it also could be your Map sensor (driver side firewall with vacum line coming off it with small filter). Hope this helps...Tony
Old May 26, 2002 | 06:42 PM
Dan's Avatar
Dan
nope, not the map sensor! I checked all the lines and cant find it!
Im getting really depressed " This bites the big one".
Old May 26, 2002 | 06:53 PM
Dan's Avatar
Dan
on the factory solenoids you only take off the two top hoses and cap them "right"? Then I just caped off the metal tubes that lead to the bottom of the actuator waste gate control, and to the bottom of the actuator turbo precontrol. Is the way to do it?
Old May 26, 2002 | 07:09 PM
93FD3S's Avatar
Big Snail
no not the top two....!!
Hey its the bottom two nipples not the top two....actually you can disconnect all four and plug them up if you want won't do any harm.
Old May 26, 2002 | 07:15 PM
Dan's Avatar
Dan
oh, thank you. I'll go try it....
Old May 27, 2002 | 11:47 AM
Dan's Avatar
Dan
Thumbs down
well, I pluged all four of the solenoid nipples and then the metal tubes. SAME **** check engine light comes on and the car idles like ****. When I hit the gas fast it almost stalls out. If I slowly give it gas the rpms will slowly rise and I can hear the turbos spool. WHAT THE HELL DID I DO WRONG? I used the little blue electrical tie in things. "You know the ones that you dont have to cut the wires" Do you think that it might be a bad connection? PLEASE HELP!!!!!!!!!!!!!!!
Old May 27, 2002 | 11:57 AM
Crash's Avatar
I tried those little blue ****'s nothing worked get rid of them asap and either soter them on or use the little brassy looking things that came withe the avc-r.
Hopefully you haven't damage your ecu or your avc-r apexi is a pain with things under warranty mounth or two wait.
Old May 27, 2002 | 12:29 PM
Dan's Avatar
Dan
I bought it used from whiteRxSeven It only came with the important stuff!
Old May 27, 2002 | 01:11 PM
Dan's Avatar
Dan
well I just went out and bought some real connecters. Im gona cut the wires in half and reconnect every thing.
This pisses me off so bad... The weather is so nice!!!
Some times I just wish I had a C5 or just even a newer z28. Or maybe a perfectly running fd. "sorry, just had to vent"
Old May 27, 2002 | 02:28 PM
Dan's Avatar
Dan
Is this my problem? the red wire that comes off the avc-r is not connected to the 6 pin coupler "it looks like it was connected at one time! The only thing that the red wire is hooked to is the ecu!! Does it need to be connected to the ecu and the 6 pin coupler? if you look at the diagram it shows that one end of the coupler only has 4 wires and the coupler that it hooks in to has 5 wires. (this dont make sense because one wire is not getting any power) So should I put it back in the connecter?
Old May 27, 2002 | 05:27 PM
Dan's Avatar
Dan
anybody? Please help, I wont hook it up until I know.
Old May 27, 2002 | 06:34 PM
Dan's Avatar
Dan
Old May 27, 2002 | 07:47 PM
daem0n's Avatar
RE-Amemiya in the blood
Hey Dan, I know it's frustrating not getting any replies. It sounds like the red wire is missing and may be a power line. I'm not sure though, maybe you should contact or check with Apex'i. I don't own one, so I don't know. But don't run the car until you know for sure.
Old May 27, 2002 | 08:38 PM
93FD3S's Avatar
Big Snail
Maybe..
Hey bro that red wire missing looks like its the power wire for the Display-Control unit.....When you turn on the Ignition Does the Display light up and does Apexi - S-AFC scroll across the Display...? I'll check mine later tonight when I get a chance. Tony
Ps....You want to make sure your connections from the S-AFC harness to the stock ECU are connected to the right wires on the ECU and are secure.
Old May 27, 2002 | 09:05 PM
Dan's Avatar
Dan
well, I have the older model. I have the red wire tied into the ecu, but it also looks like it belongs in the coupler. heres what it looks like it should be " the red wire coming from the avc-r to the coupler, and then a splice going from that red wire to the ecu"
Old May 28, 2002 | 12:20 AM
Dan's Avatar
Dan
well, I took my chances and pluged the red wire back into the coupler and it was a perfect fit (so it did belond there". then I reset the ecu and pluged the battery back up and started the car "SAME MOTHER ****** THING"check engine light comes on and runs like ****. I unpluged the map sensor both vaccum and electrical, it didnt make any difference. Then I pluged in the stock map sensor "just for kicks" but it didnt make a difference. Any comments or suggestions? please help
Does anybody want to buy a 93 fd with 45000 original miles? (j/k) but thats what I feel like
Old May 28, 2002 | 05:21 AM
stevenoz's Avatar
You didn't by chance replace your stock map sensor with the one that came with the avc-r did you? Your supposed to leave the stock one alone and use the pressure sensor that came with the avc-r to plug into the acv-r plug.
Old May 28, 2002 | 10:13 PM
daem0n's Avatar
sounds like either that's it, or if not, maybe you should try going back to stock and seeing if that works. I don't know much about this, but it sounds like you have it on no settings, the AVC-R that is. Like do you have anything that goes straight to open air with this new setup? Sounds like you don't have the proper valve settings or something, or maybe I'm not making any sense to you, just an idea from the outside, I know after you work on something for a long time you miss some things...good luck
distr0
Canadian Forum
Oct 7, 2015 08:17 AM
musker
Oct 1, 2015 05:58 PM
Linda_Lovelace
Sep 18, 2015 10:04 PM
FC_DREAMS
Sep 9, 2015 06:24 PM
