Street porting
Old Mar 27, 2009 | 05:06 PM
cerlycacktis's Avatar
Street porting
im sure that theres a thread but cant find it...Is there any shops on the west coast that anyone has used for a street port that they would recommend. Also rufly what would be the cost. The Engine is a 6 port if that helps any.
Anything helps~Stellar
Old Mar 27, 2009 | 05:18 PM
ZeroDrift's Avatar
Porting doesn't cost alot, but to do the porting you need to remove the engine from the car tear the block apart. So your most likely looking at a rebuild kit at ~$800, plus ~$200-500 to port the engine, and probably you'll encounter parts that are out of spec, so plan to get new housings, or other misc items. All in all, this can become very costly very quickly. Take a look at Atkins Rotary in Wa, and I believe Pineapple Racing in Portland Or still does engine work.
If your looking for a little more pep, get a Racing Beat exhaust system, or look into Corksport's header. There is some power to be made with a quality aftermarket header.
Good luck!
Old Mar 27, 2009 | 05:40 PM
Fumi's Avatar
Addicted to the PNW
the thread your looking for is stickyed at the top
https://www.rx7club.com/nw-rx-7-forum-33/nw-list-motor-rebuilders-tuners-rotary-specialists-performance-parts-750850/
Old Mar 27, 2009 | 05:45 PM
magnaflow is on the car from the heads back. Its made some improvement but not lots. Heads would be a good option. Ill look into that.
Old Mar 27, 2009 | 06:30 PM
ZeroDrift's Avatar
The cat-back won't do much in the way of adding power. It may shift the powerband upwards some, but more often than not you can hurt overall power by getting an exhaust that will flow too freely. Keep in mind this is regarding the S4 models, and not so much the S5 cars. Not to mention any cheap mufflers are often destroyed in a short order as the 'glass wool' will melt inside of the muffler.
I would start researching proper exhaust systems and stop thinking of porting unless your in need of an engine rebuild. Take your time and don't be afraid to spend some serious cash on a quality exhaust. Racing beat, Borla, and a few select others are actually quality. For the header and cat/presilencer, I'd stick with Racing Beat.
Old Mar 29, 2009 | 07:25 PM
ok thank you for your help
Old Mar 30, 2009 | 12:35 AM
1BADSP's Avatar
there are no heads on a rotary!!!
Old Mar 30, 2009 | 12:45 AM
PercentSevenC's Avatar
I need a new user title
Magnaflow is effectively the same as Borla internally. And no, you're not ever going to hurt performance by having an exhaust that flows "too freely". I think what ZeroDrift is referring to is the 6-port actuators not opening with too little backpressure, but as long as you have a reliable way to open them at the right time, you want to have as little backpressure in the exhaust as possible. Most important is the header design. Racing Beat's headers leave a lot to be desired. I'm not familiar with Corksport's, but it looks very similar to Racing Beat's design.
Old Mar 30, 2009 | 01:04 PM
JordanRykon's Avatar
Kunta Kinte's RX7
racing beat makes headers with 6 port actuators on there, idk about corksport if they did id probly buy them from corksport personally. if you have yours wired open tho then u rly dont have to worry about anything
Old Mar 31, 2009 | 08:50 PM
hoofhearted's Avatar
Photon co-inventor
Porting 101
Old Apr 9, 2009 | 06:59 PM
jinxed4dub's Avatar
I think he may have ment headers. but u never know
Old Apr 9, 2009 | 07:17 PM
Hyper4mance2k's Avatar
The Shadetree Project
Well, there is only one header on a rotary. If you have one... If it's stock it's jsut an exhaust manifold. So i have a rotary engineering header on my car, not headers. There are 2 headers on a typical V8 car. One header on one cylender bank and one on the other. Sorry I hate when people say headers when there is only one. 99% of Honduh kids call a header "headers"
Old Apr 9, 2009 | 07:55 PM
jinxed4dub's Avatar
my fault. header. But how is it a header, if theres no head???? We should just rename the whole part.
Housingers? there is two housings, so the s is oppropriate. jk btw
Old Apr 10, 2009 | 04:10 AM
Wholy **** you're right!!! I'm never calling it a header again! I have a housinger!! way to make my day! Awesome!!
Old Apr 10, 2009 | 07:01 AM
Red_Rabbit86's Avatar
new to the rotary world
i just call it an exhaust mani
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Ian_D
Oct 14, 2015 12:31 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
