wolf3d v3.0 tuning
Old Mar 18, 2009 | 11:26 PM
fly-low's Avatar
AB wolf3d v3.0 tuning
ive never installed a engine management system before, so question is does the standalone only monitor the engine, and if so how do you seperate the other functions of the old ecm like the dash and lighting system pretty much chassi electronics. do i have to keep the old ecm to run these functions and where would i get it tuned or start
Old Mar 20, 2009 | 10:39 AM
Aaron Cake's Avatar
Engine, Not Motor
What year of RX-7?
Old Mar 22, 2009 | 12:20 AM
fly-low's Avatar
the car is an 86 na auto gxl, being converted to 13b turbo j-spec
Old Mar 22, 2009 | 09:34 AM
FC3S.USD's Avatar
Where is my Life ?
go to wolf 3d tuning , download the manual for the v3.0 and follow them for install much simpler than you think.
But if electronics scare you and after reading it still doesnt make sense, pay someone to do the install and tune, or else you will just blow the motor one way or another ( if not from tuning from bad cas signals ).
the 3.0 is old but awesome.
Old Mar 22, 2009 | 10:28 AM
Aaron Cake's Avatar
Engine, Not Motor
All of the chassis electronics are separate from the engine electronics in the 2nd gen. Pull out the stock emissions harness and replace it with the Wolf harness. You will need to separate the wiper wiring, alternator wires and coolant temp sensor wires from the stock harness and reinstall them on the car. Those are the only stock wires you will have to mess with.
Old Mar 22, 2009 | 10:46 AM
fly-low's Avatar
thanks guys so i can just pull the stock ecu out with its engine harness, ill run the coolant sensor and gauges from an aftermaket source for reliabilty anyway and rewire the altenator but how to i maintain the wiper system to keep my controls, i do have the manual and have ben reading i even got a wiring diagram from some guy on the net with a car named sharky, well illustrated and simple, on the main plugs to the s4 ecu wich ones arent engine controls or is it only a few hidden wires in it like the ones you mentioned
Old Mar 22, 2009 | 10:48 AM
fly-low's Avatar
yeah i know its an old system but for my first i wasnt gonna spend a fortune until ive maxed this system out and need more programability, but for a fc under 350whp i should be ok right
Old Mar 23, 2009 | 02:15 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Originally Posted by fly-low
...on the main plugs to the s4 ecu wich ones arent engine controls or is it only a few hidden wires in it like the ones you mentioned
FSM Pages 4A-29 to 4A-32 will tell you exactly what each wire is for at the ECU. The largest plug (pins 1A - 1X) has all of the connections from the front harness and engine harness (don't confuse w/ EM harness). The Engine management harness uses the other two plugs.
Another site for the FSM & parts fiche: http://www.rotaryheads.com/PDF/2nd_gen/index.html
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Andrew7dg
Aug 6, 2017 01:41 PM
demetlaw
Oct 2, 2015 06:22 PM
93FD510
Oct 1, 2015 02:00 PM
