d/p on, too much boost?
Old May 23, 2002 | 08:12 PM
97VobraVert94FD's Avatar
I picked up my car from pettit yesterday after i had a dp and ast put on. I took the car out last night, kinda cool out, and i was seeing at least 13lbs of boost from the primary.... isnt this too much? I thought I would be ok with the intake and dp and the stock ecu..do i need to get a pettit ecu???
Old May 23, 2002 | 08:23 PM
rizzxx7's Avatar
DIGG7ER
you better get some type of ecu but i recommend the pfc over the upgraded ecu's because there is so much more you can do with them plus it will save you money in the long run
Old May 23, 2002 | 08:28 PM
skunks's Avatar
I'm a CF and poop smith
how much boost on the second turbo? if your strapped for cash for now, make yourself a restrictor plate.
Old May 23, 2002 | 09:32 PM
the secondary was hitting @11 or so...but the primary would just shoot up like mad. I was leaning toward the pettit ecu because i have read so much about people snapping their motors with the apexi pfc... does it come pre-programed?
Old May 23, 2002 | 09:47 PM
Mahjik's Avatar
Mr. Links
The Pettit ECU is fine if you don't plan on going crazy with your modding (single turbo or larger injectors).
Old May 23, 2002 | 10:06 PM
KevinK2's Avatar
u are likely fine for fuel, verify by dyno run before going too rich with chip.
to reduce boost, esp if fuel cut occurs, put larger pill (+.005" for start) in hose to wg act'r, or drill out integral pill if no pill in hose.
Old May 23, 2002 | 11:12 PM
Qball's Avatar
Comp Yellow Mica
go non-seq
Old May 24, 2002 | 02:43 AM
skunks's Avatar
Originally posted by Qball
go non-seq
yup, i agree. dontbearikki has a great write up as well as pics!
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
