anyone no what kind of plating yaw uses
hi
does anyone know what the name of plating paul yaw uses when he rebuilds a carb? or is there any advantage to getting the carb plated. just for street use?
Similar to the subject..... What's the best way to clean a carb when rebuilding? Once it's apart, should it soak in some sort of solvent? If so what kind and for how long? I'm about to do my carb so I'm curious. Thanks!
You can buy carb cleaner in a small bucket, and that stuff work well for getting teh dirt etc. off they also sell it in a aerosol can. But the best way to go is iff the carb body is stripped all way down then have it sonic cleaned and then mabe very litely sand blasted on the external things only. but that makes them very clean.
CJG
CJG
Trending Topics
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
rx8volks
Canadian Forum
Sep 16, 2015 09:07 PM
rx8volks
Canadian Forum
Sep 1, 2015 11:02 PM
