low boost
Old Dec 20, 2008 | 06:58 AM
Johny zoom's Avatar
low boost
Now that My engine is broken-in I want to start turning the boost up. It seems I can only boost about 7 PSI. I replace dthe BOV with a syncronic, ( I love this thing) . I took of the waste gate to be sure the seat was OK.and it was
It is a aspec T3 35R REW with all supporting mods. The turbo spins freely and continues even after the engine is shut down. I even took off the waste gate vacuum hose and still only boosted 7PSI.
Do I just have a major boost leak? Or could it be something wrong with the turbo?
Johny
Old Dec 20, 2008 | 07:04 AM
Johny zoom's Avatar
Oh. its in a FC and has no emissions, solenoids, check valves or anything else, The boost controller is an e-boost IT has always worked fine.
Old Dec 20, 2008 | 09:53 AM
Johny zoom's Avatar
I haven't pressureized the system but all the couplers are tight
Anyone
Old Dec 20, 2008 | 07:19 PM
Dudemaaanownsanrx7's Avatar
wannaspeed.com
How quickly do you get 7 psi? With a gt35r t3 you should see that boost level by at least 3k. It sounds like you either have a large boost leak. Which testing with a boost pressure tester is the easiest and simplest method. Or your wastegate is not sealing.
Old Dec 20, 2008 | 07:35 PM
Zero R's Avatar
Just in time to die
You either have a boost leak, a pre turbo leak (would feel excessively laggy) or a 7psi spring. Have you checked your wg spring? Also I never made a T3 35R kit for the FC so..... just curious what you have.
Old Dec 20, 2008 | 09:38 PM
wannaspeed.com
He said even when disconnecting the line the to the wastegate it still didn't boost higher so its prob not the spring weight
Old Dec 20, 2008 | 10:43 PM
arghx's Avatar
rotorhead
^^ he has an REW swap.
i would be really surprised if you could keep boost that low (7psi) if everything were working right, considering how prone these cars are to boost creep.
Old Dec 21, 2008 | 02:12 AM
Johny zoom's Avatar
very laggy, but Im still untuned very rich also pulls strong. I always start major and work backwards so is there possibly something wrong with the turbo?
PIC
Old Dec 22, 2008 | 08:53 PM
Zero R's Avatar
Just in time to die
I would be surprised if it was the turbo. Check your WG, pull it apart make sure it's all good in there.
Old Dec 22, 2008 | 09:35 PM
ZAN_TUNING's Avatar
Just turn up the boost!
I had this issue a long time ago on a customer car... turned out he had a clogged "high flow" cat in the exhaust. Took it out and all was well.
Old Dec 23, 2008 | 03:51 PM
Johny zoom's Avatar
I have no cats I also took apart the waste gate I have a syrncronic wastegate coming to be sure.
Sean do you have a t3 1.06 in stock? PM me if you like
Old Dec 23, 2008 | 05:07 PM
ZAN_TUNING's Avatar
no rags were left in the i/c piping last time you worked on it?
Old Dec 23, 2008 | 05:37 PM
Zero R's Avatar
Just in time to die
PM'd
Old Dec 23, 2008 | 06:40 PM
sk8world's Avatar
Chasing numbers
what thermostat housing is that?
Old Dec 26, 2008 | 02:02 PM
Dustinali's Avatar
Never Finished
Hes running the second gen front cover and second gen waterpump housing on the rew block.
Old Dec 26, 2008 | 02:14 PM
Johny zoom's Avatar
Thanks dustin Maybe the wastegate Im gettin from you will fix the prob
rgordon1979
40
Mar 15, 2022 12:04 PM
dkwasherexd
May 27, 2017 04:51 AM
AXA
Sep 5, 2015 10:06 AM
gabescanlon
Sep 5, 2015 12:09 AM
