no Spark
Old Nov 28, 2008 | 01:12 AM
jaseraserx7's Avatar
Rotor Head
Exclamation no Spark
my engine is turning but i am not getting any fire from the coils, any ideas?
Old Nov 28, 2008 | 09:31 AM
Aaron Cake's Avatar
Engine, Not Motor
OK. What year is your car?
Old Nov 28, 2008 | 10:31 AM
mortiky's Avatar
AL
checking for B+ voltage on the primary side of the coils when the ignition switch is turned on, and that the primary side is switching on & off when cranking.
Old Nov 28, 2008 | 11:08 AM
Rotor Head
it is an 86 non turbo, i checked voltage and i only have 3-4 volts going to leading coil, do you know where power is coming from right before the coils,
also i had a rat get hold of my wires going to my right head light, fixed that, and the starter cable was loose and making the car short out.
i am afraid something might be fried from that.
Old Nov 28, 2008 | 12:01 PM
JoeyMazda's Avatar
"81 RX-7
check the crank sensor
Old Nov 28, 2008 | 01:02 PM
Rotor Head
what do i need to check the cas for, 12vdc?
Old Nov 28, 2008 | 01:57 PM
Aaron Cake's Avatar
Engine, Not Motor
Pull the CAS from the engine and then key the car on. Spin it with your fingers. Do you get spark?
If no, then check the black/yellow wire at the leading coil plug for 12V with the key on. 12V?
If yes, then you have a CAS or ECU problem.
If no, then check the EGI fuse and main relay.
Old Nov 28, 2008 | 03:34 PM
rx-4's Avatar
check to see if the ecu is grounded good cause that happened on my s5 and i moved around my ecu ground and then i got spark
Old Nov 28, 2008 | 03:37 PM
Rotor Head
ok, thanks guys i'll check all that out in the morning and let you know what i find
Old Nov 29, 2008 | 09:40 AM
Rotor Head
i took out the two main srews on the cas, and it won't hardly budge. does it pull straight out? is there something i am missing? i just don't want to break it.
Old Nov 29, 2008 | 10:31 AM
Aaron Cake's Avatar
Engine, Not Motor
The CAS is held to the engine via one nut on the base.
I should mention that removing the CAS means that it needs to be restabbed correctly. Probably better to check the voltages at the coil first.
Old Nov 29, 2008 | 10:55 AM
Rotor Head
ok i got the cas out, spun it, nothing
i have half a volt at the black/yellow wire at leading coil
changed fuses main and egi comp
where is the main relay and ecu ground?
Old Nov 29, 2008 | 04:29 PM
Rotor Head
ok got it, the wires going to the main relay were chewed up, spliced them and it stared right up
Old Nov 30, 2008 | 10:52 AM
Aaron Cake's Avatar
Engine, Not Motor
Cool.
Prediict
32
Nov 18, 2015 08:41 AM
Aramir
Oct 18, 2015 02:39 AM
tctwaites
Sep 22, 2015 08:48 PM
