T60-1 with a 0.84a/r too small?
Old Oct 28, 2008 | 11:09 PM
ImamurA's Avatar
hi...i am really close to getting the t60-1...but i have been searching a couple threads and some say that the 0.84a/r turbine side will run out of breath up top...since i use the car for street and circuit i want about 350 to 400whp with minimal lag...can i use the 0.84 or should i consider going with the 1.00?...would it be a lot laggier?...thanks
Old Oct 29, 2008 | 03:41 PM
pistones's Avatar
if you have a compressor wheel that is more efficient then the small a/r won't be too bad. what about a ball bearing turbo?
Old Oct 29, 2008 | 04:11 PM
ChrisRX8PR's Avatar
I believe the 60-1 with a .84 is ideal for the Hp range you want to be in. The 1.00 A/R would be necessary if you were looking push it past 450whp. It should be fine.
Chris
Old Oct 29, 2008 | 05:20 PM
ImamurA's Avatar
yeah..its a ball bearing turbo im looking at...
Old Oct 29, 2008 | 06:24 PM
Havoc's Avatar
mate there is a 60-1 threat.
You will hit your 350, but not 400.
Also is on the small size but if you after no lag that's on the money, I would expect it to drop off a bit in the high rev range. I run a 60-1 with a 1.15 rear and fine that fine for my driving style.
Old Oct 29, 2008 | 06:31 PM
blimp's Avatar
ya i'm running .96 and i hit 353hp at 10psi revving to 7200 rpm. So ya i would go higher than .84 unless you want super response and want around 350.
Old Oct 29, 2008 | 07:13 PM
1FastT2's Avatar
Ill have to disagree. I hit 405 with that exact same turbo.
Old Oct 29, 2008 | 07:21 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
i use to have a t04s with a 60-1 comp and ptrim .84 hotside, spooled quick and power never fell off on a stock port cosmo
Old Oct 29, 2008 | 08:36 PM
fc1990's Avatar
i guss a smaller A/R would be better for track car if you dont want any lag. that is my main goal right now im have a 60-1 too but i forgot what my hotside is but im going for 350-400 with min lag.
Old Oct 29, 2008 | 09:35 PM
ImamurA's Avatar
what if i decide to go with a streetport when i rebuild in the future?...would the .84 be ok?...
Old Oct 30, 2008 | 12:58 AM
zenofspeed's Avatar
yes
Old Oct 30, 2008 | 07:19 PM
Havoc's Avatar
If that's just on pump fuel, that's the second highest recorded hp Ive seen on a 60-1.
Some guys have got higher but its been with additives (AI, WI or c16 etc.) Which is kinda cheating when comparing like turbo's.
Post up your dyno to show the others mate. Good for tech reference. so others can follow.
https://www.rx7club.com/2nd-generation-non-technical-pictures-198/60-1-62-1-club-post-if-you-have-one-742289/
Old Oct 30, 2008 | 08:58 PM
1FastT2's Avatar
https://www.rx7club.com/showthread.php?t=742289
It was with Sunoco 94oct with about 15-16psi. I'll see if I can dig out the dyno sheet, this was back in 2003 when I put down those numbers.
FOUND IT!!!
Pic of the setup.
Attached Thumbnails T60-1 with a 0.84a/r too small?-dynochart.jpg   T60-1 with a 0.84a/r too small?-modified2.jpg
Old Nov 1, 2008 | 02:09 PM
kash's Avatar
I have a T60-1 with a 1.3 a/r.... in the beginning I thought I would have some serious issues with spooling... BUT since getting the car mapped I get 15psi by 4400 rpm and it pulls like a train till 7500 rpm (18psi by 4600 rpm)
This is 15psi from 4000rpm in second till beginning of fourth...
http://uk.youtube.com/watch?v=wyYKCJnytPw
Andrew7dg
Aug 6, 2017 01:41 PM
Jetlag
Sep 29, 2015 06:52 AM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
jarjarbinks
Sep 25, 2015 11:03 PM
