Proper way to put car on jackstands
Old Oct 19, 2008 | 05:23 PM
jackattackz's Avatar
I checked the haynes manual, it only says how to jack up the front end of the car. What if I want to put the car on 4 jackstands? Do I put the front on jackstands, then jack up the rear one side at a time?
Sorry if this is a n00b question..
Old Oct 19, 2008 | 05:31 PM
Juiceh's Avatar
Saiga-12 Power!
Jack the rear up from underneath the differential.
Old Oct 19, 2008 | 05:39 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
Yep, front crossmember for the front, rear diff for the rear.
Old Oct 19, 2008 | 05:57 PM
RX07FC's Avatar
just leave it on the jack man, u will be sweet
nah wat i find best, is to use an old set of wheels, that way- it can never fall down on u.
Old Oct 19, 2008 | 06:00 PM
Icemark's Avatar
Covered in the 2nd Gen archive:
https://www.rx7club.com/2nd-gen-archive-72/properly-jacking-car-474970/
Old Oct 19, 2008 | 07:27 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
Man, that guy looks real happy that he's putting his FC on jack stands! I guess he's happy his car doesn't run
Old Oct 19, 2008 | 10:37 PM
J Wind's Avatar
what does the differential look like from under teh car? i mean... i know what it is, but uhh... its for everybody that doesn't...yea
Old Oct 20, 2008 | 02:14 AM
ion1rx's Avatar
Old Oct 20, 2008 | 03:07 AM
harley71105's Avatar
I have seen a Differential compromised by using it for jacking. Can cause it to leak...I would just go from one side to the other. Done that all my life with lots of cars with no problems.
Old Oct 20, 2008 | 03:27 AM
wheelsx's Avatar
I would assume lifting by the diff could be potentially bad if every manual says not to lift using the oil pan as a jack point. Personally, I think the car should be lifted by something absolutely sturdy like the chassis
Old Oct 20, 2008 | 06:00 AM
Turbonut's Avatar
Problem with this is that you're really causing the car to flex too much. If you have the front on jack stands and want to lift the rear, lifting from one side is definitely not a good idea. FSM is the way to go. In fact if on a surface that won't let the floor jack move, it will drag the opposite wheel as the car is raised.
When using a floor jack with the cradle, make certain the lip is around the diff and the edge won't tear the aluminum, and I know I'm a little paranoid, but I always cover the cradle with heavy cloth. Had a rubber insert at one time, but seems to have walked away.
Old Oct 20, 2008 | 08:08 AM
ITSWILL's Avatar
Wiring Nightmare
I have never had a problem lifting any car by the differential.
Also if you are lowered sometimes it is hard to get a jack under the front, I usually drive the front of the car up onto a couple 2x4s which gives me plenty of room.
Old Oct 20, 2008 | 05:11 PM
Sideways7's Avatar
FWIW, I can't even get to the diff until I partially jack up one side. And yes, I do have a nice low-profile craftsman racing jack. I normally raise up the front on jack stands, then jack up one side at the chassis-crossmember mounting point until I can get much other jack underneath the diff.
Old Oct 20, 2008 | 05:47 PM
misterstyx69's Avatar
Retired Moderator, RIP
I have to Use the aluminum scissor jack that the car came with,since the coilovers sank the car down too low. I use a Speed jack,and then place the car on Stands.Thanks to Icemark and that Happy Airhead Guy!(haha)for showing the proper way to Put the car up...who the Heck said to Leave it ON the Jack?..Fried Much?
Old Oct 20, 2008 | 06:31 PM
bokboked's Avatar
not to thread jack but if im replacing the whole rear end including the the rear crossmember where would i put the jack stands? stince i'll be removing and installing the whole thing all at once
picture of what im describing if i didnt use the right words:
Old Oct 20, 2008 | 06:39 PM
Mr.FC3s's Avatar
Rotard
I have heard of noobs lifting the car by the front crossmember and end up piercing the rad. I think its better to have 2 jacks and lifting under the suspension mount to the body. Then set your stands on something sturdy. And the rear i lift by the diff. Better yet get some ramps.
Old Oct 20, 2008 | 08:06 PM
Omixeo's Avatar
'89 GTUs
Tow hooks?
Old Oct 21, 2008 | 02:42 AM
J Wind's Avatar
Originally Posted by ion1rx
much thanks
Old Oct 21, 2008 | 02:54 AM
ion1rx's Avatar
any of you people that think it is bad too jack up at the diff couldn't be more wrong..
you jack up at the diff.. and if removing the rear sub frame.. jack up untill you can get the axle stands under the chassis rails. then use a rubber block or a piece of wood with a slot cut down the length of it bigger enough too sit on the sills with out touching the seem welded part of the body of the vehicle
Old Oct 21, 2008 | 03:33 AM
Tatakai's Avatar
i cant reach my front subframe, cars too low.
i jack up the front one side at a time, jacking from the frame rails and putting stands under the subframe.
tridav3
Interior / Exterior / Audio
Aug 18, 2015 11:42 PM
cam_7779
Aug 18, 2015 07:48 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
Marty RE
Aug 13, 2015 11:19 AM
