Haltech ok me again lol wideband q? with e6k
Old Oct 18, 2008 | 09:49 AM
timemachines's Avatar
i got an autometer wideband and i cant get to work read acurate on the e6k i got the e6ku programn n it wl read but not accurate any ideas,,,,as always help is appreciated
Old Oct 18, 2008 | 10:49 AM
classicauto's Avatar
Crash Auto?Fix Auto.
How's it wired into the haltech right now?
Old Oct 18, 2008 | 11:13 AM
ok the wideband has two wire a + signal n a - signal if i hook up the - it will read closer to wideband and the + further i got it in the spare A/D to the red/blk wire
Old Oct 18, 2008 | 11:53 AM
BDC's Avatar
BDC
BDC Motorsports
E6KU.EXE will only work with the M&W UEGO wideband unit for displaying direct air/fuel ratios. Otherwise, for every other wideband, you'll have to take the 5VDC output off the controller box and wire it into the Spare A/D on the Haltech. From there, you'll get the voltage datalogged.
B
Old Oct 18, 2008 | 12:19 PM
uhhm i thought i read some where that it works as long as u have the output,,,n i know the plx wideband works with it
Old Oct 18, 2008 | 07:04 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
E6K has no way of displaying anything other than voltage. The E6KU.exe version that Brian speaks about only will work with one particular wideband calibration.
If what ever wideband you use has a table indicating what voltage equals what AFR, just log that 0-5V signal and keep it in your head to what voltage it needs to be at for the AFR you'll need.
Otherwise, if you need to properly display and datalog wideband signals with a Haltech, you'll need an E8 or E11v2. Realistically the benefits outweigh the investment.
Old Oct 18, 2008 | 07:13 PM
boost_its_what_for_dinner's Avatar
RotoriousRx7
what about for the e6x? im just running the out wire from wb02 to the wbo2 haltech wire.
Old Oct 19, 2008 | 03:04 PM
EFI Tech Wannabe
With the E6X there a work around, when you do datalogs you can open the file in excel, and apply a formula to the mV column and get AFR, you will need to know how your particular brand of WB gets AFR from the voltage. Most will have that in their documentation.
Old Oct 20, 2008 | 02:35 AM
AnthonyNYC's Avatar
Stay tuned...
When I had my E6k, I also logged just the voltage and used a conversion table. Worked well for me.
Anthony
Old Oct 20, 2008 | 11:37 AM
ummmh ok thnx a mill
Old Oct 20, 2008 | 12:10 PM
BDC's Avatar
BDC
BDC Motorsports
Anthony
+1. That'll work just fine once ya memorize the voltage ranges you're looking for. It's not too hard at all.
B
mulcryant
Oct 4, 2015 12:18 AM
musker
Oct 1, 2015 05:58 PM
