Help with the Nest
Old May 12, 2002 | 08:40 PM
Northern 7's Avatar
Help with the Nest
Removed the emmisions today and have a little problem (and no, I do not intend to start another Rat's Nest Thread). Everything seemed to go OK until I tried to check my leading timing. For some reason the light won't even go on (and it's only a week old). Works fine on the trailing and I set the leading a few days ago with no problem ( I'm running an MSD direct fire set up and the motor runs great). I have the light attached as close to the plug as possible but I don't see this really being my problem since it worked fine before.
Anyone have any ideas - I worried that my timing may be off with the emmisions now gone. Much appreciated !!!
Oh Yea, one more thing... I now have a slight miss when idling - revs fine otherwise but I never had this slightly rough idle before the nest was removed.
thanks again
Old May 13, 2002 | 05:15 AM
yayarx7's Avatar
Are you Nucking Futs?
If the light is not working when clipped to a wire, there may be no spark coming through that wire. Check it for spark.
I do not know MSD so some other soul may be of help.
Old May 13, 2002 | 10:48 PM
V8kilr's Avatar
i recently removed my rats nest and i have an msd direct fire setup nd now my car is a pain i the *** to start???
also i noticed a couple of times the stock needle on the tach would stick @ 4k then resume when i hit 7.5k
but my aftermarket autometer would work just fine
when i find a problem i will relay i to you and maybe it will be the same,
Old May 13, 2002 | 10:58 PM
Northern 7's Avatar
No need V8kilr - I put the nest back on. I couldn't get the thing to run as smooth as it ran before taking it off. The reason my timing light wasn't working right was because my MSD was toasted. Went out and bought another one and even with the new MSD, I couldn't get the car to run / idle smooth without the emmisions. Anyway, the car works fine - shouldn't have fucked with the emmisions in the first place. If I have vac leak problems down the road, I'll try removing it again. Thanks anyway !!
Note - based on the responses (or lack of), I think most of the members are a little sick of the "rat's nest" removal posts. So.... how bout dem leafs ??
Old May 14, 2002 | 11:07 PM
yayarx7's Avatar
watsa leaf?
Old May 14, 2002 | 11:23 PM
Chemical's Avatar
a great hockey team
Old May 14, 2002 | 11:33 PM
yayarx7's Avatar
Hockey? I think we even have that in Texas now, although I bet no Texans play it.
ls1swap
Jun 3, 2024 03:25 PM
FbFuninthesun
Oct 6, 2015 08:03 AM
Jetlag
Sep 29, 2015 06:52 AM
