Two turbo ?s
Old May 12, 2002 | 11:03 AM
von's Avatar
von
Two turbo ?s
One is what kind of power will a series 5 engine make with a series 4 turbo...It should boost to stock 5.5 psi im guessing but with more power on Series 5 engine so I dont know what thats like..ANyone?
Second ? is how much money does it cost for a mechanic to drop in a turbo 11 engine from japan...Labor wise...How long should this take? THnx guys.
Old May 12, 2002 | 12:21 PM
vosko's Avatar
Just Call Me Terminator!
S4 and S5 turbos are completely different! twin scroll etc etc different manifold yadda yadda.
you mean just take out a TII engine and replace ? figure $1000 labor NO PARTS.
Old May 12, 2002 | 01:42 PM
von's Avatar
von
uuuu your kidding me right? 1000 bucks. Shouldnt this take just a few hours...My mechanic only charged me 500 in labor for a complete engine rebuild wich required all that and a little more...
I have a series 4 car with 89 engine and s4 turbo. Thats why I ask.
Old May 12, 2002 | 01:43 PM
vosko's Avatar
they are interchangeable but the S5 turbo is way better. if you got your engine removed rebuilt and reinstalled you got a steal.....
Old May 12, 2002 | 04:00 PM
Evil Aviator's Avatar
Rotorhead
I doubt that was a "complete" rebuild because the parts alone cost that much.
Old May 12, 2002 | 04:10 PM
CanadianRX7's Avatar
von said $500 in labour not parts.
Old May 12, 2002 | 04:19 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
I got some parts for my NA dirt cheap like as in 5 bucks for a water pump cause they guy wanted it gone. its possible.
NZConvertible's Avatar
I'm a boost creep...
Re: Two turbo ?s
The compressor (intake) side of the two turbos are identical, it's the turbine (exhaust) side that's different. At the same boost there's probably a 5-10hp advantage with the S5 turbo and manifold. Note that the wastgates are also identical; the S5's higher boost was achieved by an ECU controlled bleed solenoid on the wastegate line. Stock S4 boost is 6.56psi.
Old May 12, 2002 | 04:40 PM
Felix Wankel's Avatar
Super Newbie
The wastegates are not identical. The S5 has two ports instead of one on the S4.
Old May 12, 2002 | 05:17 PM
Rotorhead
Oh, my bad.
That was a good deal, then, depending on what was charged for the parts. An in-car rebuild in my area is about $2,000 parts & labor.
Reading the original post again, I see that the question is about a J-spec TII, not an American model. Yes, this will be more expensive than an American TII engine because they are not 100% interchangeable. I would ask the mechanic who rebuilt the engine what he would charge for this, as it looks like his pricing is pretty good.
Old May 12, 2002 | 06:15 PM
von's Avatar
von
Ok...I paid 23oo for my complete engine rebuild. Im just saying I paid 500 for 12 hours labor including taking the engine out , rebuilding and putting it back in... I was just asking how much it would cost for a mechanic to just put one in from japan already dressed. The one thats in thier now is jspec so it should swap right in?
SO how much ya think...I mean its not important i can just call the guy up and ask. Thnx
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
